Alienware M14x R2 with 7 beeps error
    Re: Alienware M14x R2 with 7 beeps error
    Originally posted by caspian View Post
    fix the CPU_VCore circuit.
    What voltage should PL703, PL704, and PL705 be showing?
      they should be about 1 volt.
        Seeing my original readings where 0.9mV for those three should they be right? Or should they be on the higher side around 1.2V? I haven't had time yet to do any new testing with the LCD cable on.
          was it 0.9mV or 0.9V?
          if 0.9mV, it is considered as no voltage.
            Ah ok, I'm sure it was 0.9mV, I'll have to confirm in a few days when I get some free time :-)
              I'm getting 0.0mV across PL703, PL704, PL705 with and without the LCD connected, so I'm not sure how I got the last readings, what should I test next?
                PC733, PC734, and PC766 are 25V 100U caps that had around 10V in them each when turned on then over roughly 30secs they rose to 17V each before I powered down, does that sound right?
                  there is no PL705 and PC766 on this board.
                  first measure voltage on all pins of PQ700 after turning on.
                  then, measure voltage on all pins of PU700 if you got time.
                    What do you mean, PL705 and PC766 are both on page 59, are you useing the schematics I posted in post #9? My schematics don't have PQ700 and PU700.
                      I found them.
                      yes 17v is normal for that point.
                      remove the battery from your laptop until you fix it.
                      now measure voltage on all pins of PU701 after turning on.
                      avoid shorting neighbor pins together.
                        The Cmos battery?
                          no, remove the main battery.
                          if you remove the cmos battery, it would be safe too.
                            The board is out of the casing as the components being tested are on the bottom of the board.
                              I'm still testing but I get slight fluctuations each time the 7 beeps start
                                to make sure, measure voltage on all the 3 pins of PQ1.
                                and read the voltage written on the AC adapter brick.
                                also measure voltage on PL302 after turning on.
                                  PU701
                                  1 - 0.6mV
                                  2 - 0.6mV
                                  3 - 0.6mV
                                  4 - 0.1mV
                                  5 - 0.844V
                                  6 - 1.060V
                                  7 - 0.978V
                                  8 - 1.060V
                                  9 - 3.290V
                                  10 - 0.2mV
                                  11 - 0.9mV
                                  12 - 0.9mV
                                  13 - 0.9mV
                                  14 - 0.9mV
                                  15 - 0.9mV
                                  16 - 0.9mV
                                  17 - 0.9mV
                                  18 - 0.2mV
                                  19 - 19.5mV when not beeping, 19.9mV when 7 beeps are sounding
                                  20 - 2.256V when not beeping, flashes between 2.256V and around 2.201V when 7 beeps are sounding
                                  21 - 0.9mV
                                  22 - 0.9mV
                                  23 - 0.1mV
                                  24 - 1.350V when not beeping, flashes between 1.350V and around 1.310V when 7 beeps are sounding
                                  25 - 2.575V when not beeping, flashes between 2.575V and around 2.490V when 7 beeps are sounding
                                  26 - 2.576V when not beeping, flashes between 2.576V and around 2.490V when 7 beeps are sounding
                                  27 - 0.9mV
                                  28 - 0.9mV
                                  29 - 0.9mV
                                  30 - 2.264V when not beeping, flashes between 2.264V and around 2.220V when 7 beeps are sounding
                                  31 - 2.267V when not beeping, flashes between 2.267V and around 2.213V when 7 beeps are sounding
                                  32 - 0.5mV
                                  33 - 0.5mV
                                  34 - 0.1mV
                                  35 - 1.344V when not beeping, flashes between 1.344V and around 2.220V when 7 beeps are sounding
                                  36 - 0.5mV
                                  37 - 0.1mV
                                  38 - 0.5mV
                                  39 - 0.5mV
                                  40 - 0.5mV
                                    PQ1 has no component from factory, what do I do with it?
                                      PL302 was around 0.2mV to 0.0mV, not sure if those readings are wright, will have dinner and come back :-)
                                        instead, measure voltage on PL102.
                                          now measure voltage on PL205 and PL202.
