please i really need help urgently, a client brought this HP dv6 laptop and you you on it the power led light comes and goes,after making some checks on mobo I find out that is multi legs ic pu16 if am correct,PQ 5 is closer to it was warming so i removed it and tried to on the board with it,the power came on but after replacing the said ic,when you press the switch it comes and goes off again without that ic warming again,please what am i missing?mobo number is DAOUT1MB6E0 REV:E,tnx in advance
Hp dv6 with power issue
Tags: None
Re: Hp dv6 with power issue
UT1. That sounds familiar. You most likely have a defective AMD Northbridge. This board rarely has power issues.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by justice171I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:- Verified that all critical voltages are present:
- 3.3V and 5V are always present if DC is plugged.
- 1.8V on the BIOS chip is present.
- Checked the power button functionality:
- When pressed, the voltage drops to 0V, indicating the button is functional.
- Inspected the flex cable connecting the USB, audio, and power button to JUB1:
- Confirmed connectivity is intact, ruling out issues
11-26-2024, 12:39 AM - Verified that all critical voltages are present:
by claws77hi guys, my motherboard will not start no matter what
when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
but rest nothing happens no sign of life.
this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
but now nothing happens no matter how much i wait/ charge/ press and hold power button.
i have no knowledge of motherboards ....10-20-2024, 02:48 PM -
by yaya3gmaxDell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
Symptoms:- Laptop works normally on a pre-charged battery.
- Battery does not charge when adapter is connected.
- Without battery:
- Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
- Speakers “pop” when power cut occurs indicating harsh sutdown.
- If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
by SuperJamesThis one's a weird one, and still unsolved despite it having gone back to Dell once.
Specs
i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
Backstory
I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...10-23-2023, 04:09 PM - Loading...
