please I urgently need help,I have this Dell laptop when you put in the charger,the led on power jack comes on and goes off,but comes on again only if you put in the battery,but laptop does not on,after checking the board i relies PL2 becomes warm and I even changed PR134 but still problem is there,can someone please help,model number Dell PP39L and board number is DA0FM8MB8E0 REV:E
Dell PP39L with power issue
by SuperJamesThis one's a weird one, and still unsolved despite it having gone back to Dell once.
Specs
i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
Backstory
I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...10-23-2023, 04:09 PM -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by VenDell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
Issue Description:- CPU Overheating to 100°C
- When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.
- When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
- However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
- I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
- Thermal
2 Photos - CPU Overheating to 100°C
by NotEnoughHi everyone,
I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
What I've Tried So Far:- Reseated the cables.
- Reinstalled AWCC and AlienFX services.
- Attempted BIOS downgrade but no improvement.
- Inspected ribbon cables for damage.
- Explored the possibility of BIOS or
The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
- Loading...
