Gateway laptop with power problem
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    please I urgently need help with this Gateway laptop I have here the model is SA1,when i plug in the charted to the power jack I don't get 3.3v under the power switch,I have tested
    PQ19
    PQ22
    PQ50
    PQ9
    but all looks OK, it's only PQ37 which gives me 19v at all pins and I don't know if it should be so,please anyone can help on what to test again,tnx in advance
    Mobo number is DA0SA1MB6E0 REV:E
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3605
    • slovakia
    Re: Gateway laptop with power problem
    no help without schematic
    • emmanuelbill1988
      • Mar 2017
      • 100
      • ghana
      please can anyone help me with the schematic?so that I can be helped
      • piernov
        • Jan 2016
        • 4436
        • France
        First link on Google man… https://cdn.badcaps-static.com/pdfs/...9a472ce0a2.pdf
        • emmanuelbill1988
          • Mar 2017
          • 100
          • ghana
          PQ38 becomes hot when i put the charger in power jack,so I replaced it after which the board worked when I switch power on,but I realised when i remove the charger from the power jack and put it inn again i don't get the 3.3v under the switch and the laptop doesn't turn on when switch is pressed,really need help
          • boyebaran
            • Sep 2015
            • 247
            • iran
            Hi
            measure all pin U7 (connect adapter)
            • Tatto
              • Jul 2020
              • 8
              • España
              Originally posted by piernov
              Many thanks Piernov
              • Syscom0
                • May 2021
                Hi:
                I know this is years latter, but let me try my question:
                Did you resolve the issue? Which MOSFET(s) were responsible. Someone suggested U7, but that is a fan controller. Noting to do with issue at hand.
                Let me thank you in advance if you remember the details, and respond.
