Case studies
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Case studies
    Anyone can post your experience on this thread.
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Case studies
    Hi friends,
    I had a problem on HP Probook 450 G2 Laptop. The charger indicator ( Orange light ) was blink. I checked 19V line and FETs Everything working fine. I replaced the charging IC BQ24736 by BQ24725 ( Checked Datasheet was Same ). But no use its doing the same. I check The DC/DC Converter ( 3V /5V). checked LDO 3V is ok. but on LDO 5V is showing 3.98V and the output coils( 3v/5v ) not showing and voltages. So i try to find the replacement for RT8243AZQW. But i couldn't find and finally i ordered it on ebay. after two days i got free time to check this again. I check all resistors and capacitors around RT8243AZQW chip. Finally i found PR321 ( 499K ) was opened. I replaced it now the laptop working fine.
    • dspok
      • Jan 2014
      • 553
      • Nepal
      Re: Case studies
      Good idea Raajkumar.
      • dspok
        • Jan 2014
        • 553
        • Nepal
        Re: Case studies
        Hp 15-r001ne
        Power on instant off. No display.
        No shorting, RAM and all enclosure OK.
        Reprogrammed 9012 and BIOS, system works fine. ��
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3591
          • slovakia
          Re: Case studies
          Originally posted by raajkumar
          Hi friends,
          vin and enable signal si first to check, but good work
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            Re: Case studies
            Originally posted by dspok
            Hp 15-r001ne
            Good job.
            • raajkumar
              • Mar 2015
              • 354
              • Srilanka
              Re: Case studies
              I think no one willing to share their experience with others.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Re: Case studies
                I think you may be attempting to duplicate the intent of this forum on your thread. So I think no one would be interested.
                • raajkumar
                  • Mar 2015
                  • 354
                  • Srilanka
                  Re: Case studies
                  No i am not doing like that. if anyone like they can share.
                  • dspok
                    • Jan 2014
                    • 553
                    • Nepal
                    Re: Case studies
                    Sony laptop (forgot model)
                    Problem: power on but sometime display sometime no display.
                    If display comes bios post produce error "Resource Conflict -PCI in slot 01 bus:08, device:03, function:00"
                    Solution: Removed card reader ic, problem solved.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3591
                      • slovakia
                      Re: Case studies
                      Problem solved?
                      NO
                      • dspok
                        • Jan 2014
                        • 553
                        • Nepal
                        Re: Case studies
                        Yes problem solved. 100%
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3591
                          • slovakia
                          Re: Case studies
                          so your card reader work without its chip?
                          NOT SOLVED
                          if u solved it, then your card reader will work
                          • dspok
                            • Jan 2014
                            • 553
                            • Nepal
                            Re: Case studies
                            NOT SOLVED
                            Hahaha, you are right inbuilt card reader will not work but at least no display and display error is solved.
                              ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                              This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 10:50 PM
                              ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                              This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 11:05 AM
                              ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                              This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                              This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                              This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 07:07 AM
