DV6000 Intel
  • rigeback
    • Mar 2011
    • 421
    • Malta
    DV6000 Intel
    Hi there,
    I was trying to start my friends DV6000 by shorting the terminals where the flat ribbon connectors locate to the power button and the cap circled in red next to the power in plug blew.
    My knowledge of schematics is not so good and I was hoping some could identify this caps value so I can try replacing it.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3576
    • slovakia
    Re: DV6000 Intel
    these laptop starts with shorting two triangles between conectors with these ribbons
    firs cap have under it label/looks like PC146 dont see first digit because of red line/
    second is in D. so look for D label on board where is labeled its label
    • rigeback
      • Mar 2011
      • 421
      • Malta
      Re: DV6000 Intel
      Yes I see the solder triangles but was trying to short the ribbon connectors.
      The Cap is the one next to PC146 but I do not see it in the schematic to obtain a resistance value
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3576
        • slovakia
        Re: DV6000 Intel
        the cap net to it is diode PD18
        • rigeback
          • Mar 2011
          • 421
          • Malta
          Re: DV6000 Intel
          Yes but PC146 = 10U/25V_12 on the VIN line, this does not seem to be the correct value of the cap that blew
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3576
            • slovakia
            Re: DV6000 Intel
            why?
            • rigeback
              • Mar 2011
              • 421
              • Malta
              Re: DV6000 Intel
              10uf is correct?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3576
                • slovakia
                Re: DV6000 Intel
                if its vin it doesnot matter. it even must not be there
                • rigeback
                  • Mar 2011
                  • 421
                  • Malta
                  Re: DV6000 Intel
                  My board looks this after the cap blew. might not be the VIN line
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3576
                    • slovakia
                    Re: DV6000 Intel
                    yep. it is vin shorted to ground
                    • rigeback
                      • Mar 2011
                      • 421
                      • Malta
                      Re: DV6000 Intel
                      I'll try and solder a new cap but running out of space unless I remove the complete plastic plug. The board with jack might also have a problem since the blue led is not coming on.
                      • rookieme
                        • Oct 2014
                        • 396
                        • Greece
                        Re: DV6000 Intel
                        Do remove the power board [dc jack] from the main board and try it again with the power adapter to check is blue led lights up.
                        Maybe your mainboard is still shorted and also shorts the dc in.
                        The PC146 is not very nessesary to be placed again by you sure need to clean the burn and check that not longer shorts there.
                        • rigeback
                          • Mar 2011
                          • 421
                          • Malta
                          Re: DV6000 Intel
                          Back again! I would like to continue this thread as I have replaced the cap at the power connector and the board is powering up but not starting, when shorting the arrows the boards lights and fan come on briefly.
                          I've disconnected Coil PL23 to check the transistor PQ33 which seems OK but not confirmed,, any hints?
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3576
                            • slovakia
                            Re: DV6000 Intel
                            u must check all big coils for voltage, and if not find, than check for short on it.
                            off course u finding voltage after pressing power button
                            u have short in some power switched rail, or bad PWRGOOD logic
                            • rigeback
                              • Mar 2011
                              • 421
                              • Malta
                              Re: DV6000 Intel
                              no power going to the coils, will try to test them off the board
                              • rigeback
                                • Mar 2011
                                • 421
                                • Malta
                                Re: DV6000 Intel
                                OK I made starting short and I'm getting some power to L22 and L23. On L22 very low around 0.20V on one leg and nothing on the other, bad coil?
                                L23 gets 5.00V + on 1 leg, the other .99V. Is this 2 bad coils or in the main PWRGOOD line??
                                • rigeback
                                  • Mar 2011
                                  • 421
                                  • Malta
                                  Re: DV6000 Intel
                                  took both off the board and they test good
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3576
                                    • slovakia
                                    Re: DV6000 Intel
                                    resistance to ground ?
                                    make this on ALL big coils/GREY CUBE/, and check for voltage when starting
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3576
                                      • slovakia
                                      Re: DV6000 Intel
                                      as u starting u must have 3,3V line good
                                      • rigeback
                                        • Mar 2011
                                        • 421
                                        • Malta
                                        Re: DV6000 Intel
                                        PL22 gives 51 Ohms PL23 4.2 Ohms resistance.
                                        there is 3.3V and 4.8V available. the battery charging system is working.
                                        It seems PQ33 might be faulty during starting, most times the voltage is very low and occasionally 2.3V will be enough to spin the fan. 17.80V on feed side
