Toshiba satellite pro with display problem
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    I have this Toshiba satellite pro with display issue, when you put inn the charger the power led light comes on and when you press the start switch the second led light comes on after few seconds goes of and come back on but processes does not heat ,motherboard number is LA-6841P Rev:1.0,please someone should help me out,much grateful
  • Seagorman
    • Apr 2017
    • 70
    • Ireland
    Re: Toshiba satellite pro with display problem
    Hi emmanuelbill1988, could be a problem with the Motherboard but worth trying one or two small things first, remove the battery and the charger, hold down the Power button for approx. 30 seconds then try turning on again with just the charger plugged in, if no luck retry with just battery in, any luck?, if not remove the Ram, clean the contacts & reseat, if the same is still happening post full details of the laptop ie. exact model no, CPU, Ram etc.
    • Seagorman
      • Apr 2017
      • 70
      • Ireland
      emmanuelbill1988, you could also try removing the internal CMOS battery, leave laptop sitting for a while with main battery and charger disconnected, try booting without reconnecting CMOS battery, laptop will hopefully post but with errors relating to time date etc., you could then reconnect CMOS battery enter the BIOS and reset date etc, if this works, replace the CMOS battery with a new one, all failing then it will be time to start looking at the Motherboard
        09-06-2024, 05:27 AM
        Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
        This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
        This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
        09-06-2024, 06:10 AM
      • zioricci
        Toshiba Satellite P855 charger disabled after a while
        by zioricci
        after a little operating time of my Toshiba laptop, ranging from about 20 to 45 minutes, the Power light goes off, the power supply switches from the charger to the battery and in fact the voltage of both gates of the 2 initial mosfets are at 0V so the 19V does not reach the PL201 inductor and the power comes only from the battery.
        However, when i close the cover to turn off the laptop, the charger starts working again, charges the battery and the Power light turns on in amber color but after about 20 minutes the charger is disabled and the power light...
        05-05-2023, 02:34 PM
      • alro7779
        Samsung UN55MU6103F video problem; has colored stripes on the display
        by alro7779
        Hello, everyone!
        A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
        09-27-2025, 11:29 PM
