HP Pavilion dv6 2010SA running temperature?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have a HP Pavilion dv6 here to fix. When I first got it, the laptop would shut down after 10-15 mins or so when turned on from cold, even if just idling.
    Using HWMonitor the core temperature would read about 70c and quickly rise up towards 90c+ if there was amount of processor load happening, such as when loading an app. The fan was rather noisy too. After a short time the screen would go blank, then the PC would shut down. Once it had cooled you could restart it (it would say restoring windows and boot back to HWMonitor running so it must have been shutting down properly, not crashing)
    I stripped it down and cleaned all the brown sh!t and crap out of the processor fan (why do people smoke when using laptops!??! ) using a paint brush then compressed air.
    Once rebuilt, it is now running much cooler (around 53C idling). I run it for an hour or so no problem, then gave it a bit of work to do - playing music via Windows Media Player with Alchemy Vizualizer.
    If I then overlay the HWMonitor window over the visualizer I can see the core temp at about 80C but with the monitor window over the visualizer it will climb up to 98C or 99C. It seems the overlaid window increases the CPU load generating the vizualizer. A couple of times i got it to hit 100C but the fan then works fast and almost instantly drops it back to about 90C.
    This is all with laptop flat on the desk, if I prop up the edge near the fan about 1 inch from the desk, it drops by about 10 degrees
    My question is - have I fixed it or is it still running too hot? After cleaning it's never shut down even when I got it to hit 100C core temp
    The laptop has no battery fitted (customer has lost or chucked it!)
    FWIW - and it must make a difference - I'm in south Gran Canaria so ambient outdoor temp is 26C today. I have workshop windows open so it is about the same.
    Follow me on YouTube
    Learn Electronics Repair
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: HP Pavilion dv6 2010SA running temperature?
    so check live cpu load with overlay
    use cpu killer on 98% for 1hour for all cores to be sure that cooling is ok
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Cheers
      I got that cpukiller free download. It times out after 20 mins per session and says you have to register.
      However I think it proved the point. Using this at 99% cpu load the temperature topped out at 100C occasionally but would drop instantly when it hit that.
      Mostly it was sitting in the range 90C-95C
      I ran it twice for 20 mins each session and the laptop never powered down. Actually I have had it switched on idling all afternoon and it's been stable.
      So I guess the cooling is working OK now
      Rich
      • rookieme
        • Oct 2014
        • 396
        • Greece
        Have you checked if you have the latest bios?
        HP usually makes some fixes regarding the cpu fan speed.
        You can also check the change log of newer bios is you have an old one just to be sure.
        Some good programs for the cpu are heavyload and prime95 [both are free]
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Thanks rookieme I will check the bios.
          I do have prime95
          rich
          • piernov
            • Jan 2016
            • 4435
            • France
            You could try Speedfan to see if it gives the same reading (that's the one which usually works the best for me, I also use lm_sensors on Linux).
            Also you'll have to replace the thermal paste (optionally the thermal pads too if they don't look good, they can leave some liquid on the chips and kill them). Also check if the heat pipes are damaged. And make sure you properly mount the heatsink.
              HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
              This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
              09-12-2024, 03:44 PM
              HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
              This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
              This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
              This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
              HP Pavilion Pavilion p6103uk Pavilion p6100 E5200 Specification for Upgrade or Repair
              This specification for the HP Pavilion Pavilion p6103uk can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6103uk boardview and Pavilion Pavilion p6103uk schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-12-2024, 03:36 PM
