msi netbook u135dx battery not charging
  • String2016
    • Nov 2015
    • 2234
    • philippines
    Re: msi netbook u135dx battery not charging
    thanks for the response mielta i have check at page 21 here is the reading below battery plugged in and charger plugged in
    PQ11 PIN 1= flashing voltage from 12.99 to 13.02
    2= 1.14V
    3= flashing voltage from 12.99 to 13.02
    4= 1.67V
    5= flashing voltage from 12.99 to 13.02
    6= 0.21V
    7=flashing voltage from 12.99 to 13.02
    8=flashing voltage from 12.99 to 13.02
    PQ3 PIN 1= 19.14V
    2= 1.74V
    3= 19.14V
    4= 19.13V
    5= flashing voltage from 12.99 to 13.09
    6= flashing voltage from 12.99 to 13.09
    7= 19.02v
    8= 19.19v
    MAXIM8724E PIN 1= 18.8V
    2= 5.33V
    3= 4.07V
    4= 2.9 V WHEN PROBE TOUCH LED LIGHT OFF
    5= 0.99V
    6= 0.65V
    7= 0.65V
    8= 3.27V
    9= 5.3V
    10= 2.25V
    11= 0.06V
    12= 3.29V
    13= 0.65V
    14= 0V
    15= 5.34V
    16= 12.56V
    17= 9.36V
    18= 12.57V
    19= 12.56V
    20= 0V
    21= 0V
    22= 5.34V
    23= 13.4V
    24= 2.37V
    25= 5.04V
    26= 19.2V
    27= 19.2V
    28= 5.93V
    anyone please advise and help please
    • mielta
      • Apr 2015
      • 368
      hi
      you must mesure only battery plugged in
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        This mobo very weird I think. IC charger use MAX same with msi wind 100, but first mosfet near dc jack same with MS-N0141-0A. So Confused
        • String2016
          • Nov 2015
          • 2234
          • philippines
          here is the reading only battery plugged in
          PQ3 multimeter set to 200ohms
          p1 and p4= 102.8ohms
          p4 and p5= 92.8ohms
          p1 and p5= 102.6ohms
          p2 and p4= over 200ohms
          p2 and p5= over 200ohms
          p3 and p4= 102.5ohms
          p2 and p1= 102.8ohms
          p3 and p5= 123.5ohms
          p1 and p6= 130.2ohms
          p1 and p7= 104.9ohms
          p1 and p8= 105.2ohms
          p2 and p6= over 200ohms
          p2 and p7= 199.7ohms
          p2 and p8= over 200ohms
          p3 and p6= 129.9ohms
          p3 and p7= 104.7ohms
          p3 and p8= 104.7ohms
          PQ11
          p1 and p4= 99.9ohms
          p3 and p4= 99.9ohms
          the rest pins there is no reading
          anyone please help on this please
          • mielta
            • Apr 2015
            • 368
            Hi
            sorry you must messure voltage within Battery.
            • String2016
              • Nov 2015
              • 2234
              • philippines
              #26
              there is no voltage on pq11 and pq3 if battery plugged in only
              • mielta
                • Apr 2015
                • 368
                Hi
                on pin5+6 from pq3 there must be the voltage of the battery.
                please messure direkt on pin1 and 9 from the battery there must be ca.11volt
                userwise the battery is defect
                • smali
                  • Sep 2014
                  • 287
                  • Pakistan
                  #28
                  @string2016....start your laptop with both battery and adopter goes to device manager in window and then select batteries in device manager and uninstall all three option in batteries and restart your laptop and then post result.
                  • String2016
                    • Nov 2015
                    • 2234
                    • philippines
                    #29
                    @mielta pin 5 and 6 of pq3 there is no voltage and also battery no voltage on 1 and 9 pin but when charger plugged in and boots on windows battery at taskbar is 30% and charging but stuck on and also cannot power on with battery only
                    • String2016
                      • Nov 2015
                      • 2234
                      • philippines
                      #30
                      @battery detected and charging but problem is stuck on 30% and also cannot power on when battery only plugged in
                      • smali
                        • Sep 2014
                        • 287
                        • Pakistan
                        #31
                        are u done what i said? i think your battery is actually 0% but it shows 30% as i said uninstall all option in batteries in device manager and restart your laptop as i said in my previous post.
                        • meritosari
                          • Oct 2010
                          • 774
                          • Indonesia
                          #32
                          When measure voltage on component or test point you should set your DMM to DC mode, please don't use ohm mode to avoid to damage your DMM.
                          Post a photo when you are reading your DMM, would be help.
                          • String2016
                            • Nov 2015
                            • 2234
                            • philippines
                            #33
                            @meritosari Ive measured in dmm in ohm mode battery only plugged in I already done measured in dc voltage set to dc mode pq3 there is no voltage once battery only plugged in
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                              NVDC charger configuration...
                              11-05-2024, 03:28 PM
                              Bauer tool battery pack charging with a HERCULES charger modification
                              by sam_sam_sam
                              The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                              Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                              05-06-2023, 12:17 PM
                            • flat-earther
                              ASUS X54H laptop thinks it's always charging even with charger unplugged
                              by flat-earther
                              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                              Windows also shows ''Plugged in'' when charger is not connected.
                              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                              If I let battery run out and say it has 3% Windows will...
                              06-24-2025, 09:32 AM
                            • serious_electron
                              Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                              by serious_electron
                              Hello Everyone!
                              I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                              06-28-2025, 02:57 PM
