Dell la-9104p laptop 2beep
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    LA-9104p motherboard 2 beep. ram is ok. clean the ram slot but same error how to fix this error.
    any one help me plz
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    Re: Dell la-9104p laptop 2beep
    plz. any one help me
    • petehall347
      • Jan 2015
      • 4428
      try different slot and different ram
      • vickey_vip
        • Mar 2016
        • 134
        • India
        are you getting ram voltage on ram ic ?
        • Sanjeewait
          • Aug 2016
          • 63
          • Sri Lanka
          voltage is ok, ram good, 2 slot same error
          • techman1025
            • Jun 2014
            • 497
            Hi
            Try one slot at a time ..if works just double up on it and call it a days not worth fixing .
            Techman1025
            • marouen92
              • Dec 2017
              • tunisia
              i have the same problem i tried different ram but the same result... i checked the slot and i read 0.75v on eatch pins 203,204 any one can help? thanks
              "The Quieter You Become The More You Can Hear"
              • Bloodhoundje
                by Bloodhoundje
                03-16-2024, 03:12 PM
              • mikey5791
                Dell laptop model PP24L won't start from ac adapter
                by mikey5791
                Dear all,
                Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                03-24-2023, 09:06 PM
              • Mots06
                Old Dell E5400 Laptop ( Purchased in the year 2008)
                by Mots06
                Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                07-19-2025, 01:56 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Calidebear
                Dell 3537 laptop doesn't boot without embedded display.
                by Calidebear
                I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                So checked the schematics to bypass this issue.
                Found something but I don't know how to read this schematics.
                Dell 3537 mobo 9982p rev 3
                Schematics attached,...
                03-29-2025, 11:37 AM
