Acer Extensa 2509-C6l8. Auto off 5 Sec.
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Have a Nice Day to all Badcapsters.
    I need a advice to my Repair. Acer Extensa 2509-C6l8
    Mobo: Z5WAL LA-B211P (Rev: 1.0) 2014-03-26
    Symtoms: if i turn on Processor Fan not Spinning After 5 sec Turn off.
    Other : error first Shorted the USB Connector. i'll already remove the USB port
    1. i check the voltage.
    check the PQ302 (MOSFET MDU1512) Nchannel marked red box. test actual
    On plugin addpter( system turn off)
    Using Digital Test
    S 123=19.59V
    G 4 = 0V ?
    D 5678= 19.59V
    On plugin addpter( system turn on)
    Using Digital Test
    S 123=19.59V
    G 4 = 0V ?
    D 5678= 19.58V
    First question Here the picture
    Source Prove Red the Black on Gnd
    then the Drain same reading on Source.
    second question if the Gate have no supply
    maybe this is happen?
    but how come (1) why?
    i need for advice and Help me to fix this. thanks
  • String2016
    • Nov 2015
    • 2229
    • philippines
    Re: Acer Extensa 2509-C6l8. Auto off 5 Sec.
    Can you upload schematics please
    • lorins_core
      BlackSmith
      • Dec 2012
      • 551
      • Philippines
      here Sir
      compal_la-b211p_r1.0_schematics.pdf
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        Follow Up...
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          Help... pls
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            Mosfet in short ? Post the schematic.
            • lorins_core
              BlackSmith
              • Dec 2012
              • 551
              • Philippines
              Are you Sure Sir? the mosfet is Short?
              can you explain me Why Mosfet is Short? for your Respect
              here's the Schematic Diagram
              Thanks for reply
              • lorins_core
                BlackSmith
                • Dec 2012
                • 551
                • Philippines
                Symtoms: if i turn on System. but Processor Fan not Spinning. After 5 sec system Turn off.
                [ATTACH]152295[/ATTACH]
                Using Digital Test
                S 123=19.59V
                G 4 = 0V ?
                D 5678= 19.59V
                Using Digital Test
                S 123=19.59V
                G 4 = 0V ?
                D 5678= 19.58V
                [ATTACH]152296[/ATTACH]
                [ATTACH]152297[/ATTACH]
                [ATTACH]152298[/ATTACH]
                Help me to Solve it.
                • lorins_core
                  BlackSmith
                  • Dec 2012
                  • 551
                  • Philippines
                  Follow Up Again.
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    I think you should use scale 200V to measure volt on gate PQ302. How could be?
                    PQ302 its N-Channel mosfet. N-channel need voltage on gate with value vgs is positive (+) than source. pin 123 we need 19V. So, on gate we need higher than 19V. could be 19V+6V. (voltpin4-voltpin123= +). so on gate pq302 usually ~24-25V. And your dmm can't reading properly if you set 20V scale.
                    • lorins_core
                      BlackSmith
                      • Dec 2012
                      • 551
                      • Philippines
                      Thanks I Try it late and I post the result
                      • lorins_core
                        BlackSmith
                        • Dec 2012
                        • 551
                        • Philippines
                        Update: Not Yet Done
                        Unit Statuz: Auto Off 10 sec. CPU Fan Not Spinning
                        Power Led Indicating if press power on switch Light After 10 sec. Turning Off the light
                        hints: I already change the PQ302 same value
                        voltage value plug in the adapter
                        PQ302
                        S-123 = 19.5V
                        G-4 = 24.7
                        D-5678= 19.5V
                        PQ303
                        S-123 = 19.5V
                        G-4 = 24.7
                        D-5678= 19.5V
                        PQ301
                        PIN1 = 24.7V
                        PIN2 = 2.7
                        PIN3 = 19.5V
                        What Parts Have problem?
                        • lorins_core
                          BlackSmith
                          • Dec 2012
                          • 551
                          • Philippines
                          Follow up....
                          • lorins_core
                            BlackSmith
                            • Dec 2012
                            • 551
                            • Philippines
                            Follow up... Again. I have no Idea. Plssss Help
                              ACER Extensa Extensa E264 Extensa E2200 Specification for Upgrade or Repair
                              This specification for the ACER Extensa Extensa E264 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa Extensa E264 boardview and Extensa Extensa E264 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-12-2024, 03:36 PM
                              ACER Extensa M2710 Extensa M2 i5-6400 Specification for Upgrade or Repair
                              This specification for the ACER Extensa M2710 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa M2710 boardview and Extensa M2710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                              09-12-2024, 03:30 PM
                              ACER Extensa M2710 Extensa M2 i3-6100 Specification for Upgrade or Repair
                              ACER Extensa X2610 Extensa X2 J3060 Specification for Upgrade or Repair
                              This specification for the ACER Extensa X2610 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Extensa X2610 boardview and Extensa X2610 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
