I need someone from Gabon to help a friend who is in need of a techinician.
Anybody from Gabon on this page
by gurujihello
I have this weird machine that came with power issue fixed the power supply now the machine boots up but the USB ports don't work.For some strange reason if I press Option and boot from pen drive I can use the usb all ports work.there is something that disables the usb when comes to login page. I reprogrammed the bios same problem.the ssd in this machine has Catalina and when I go to boot with high Serria usb bootable it gives me a cross that os not compatible with the machine.only Yosemite usb bootable works.So is there some terminal command that disables the USB ports.is it that... -
by Geeker007Hi All,
So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
I have not tried putting... -
Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
- It started with a bright and greenish picture upon starting a cold monitor.
- About 2 years ago, only on the cold boot, the screen started to occasionally flash with
by fredyjbiplease help friend extract bios file from website FL1 exe to bin thinkpad p1 gen 3 no display beep melody thank you...
Channel: BIOS Requests ONLY!
by tony359Good day all,
I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
Once the fan was swapped, I installed an OS and it worked fine.
The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
If I see that right, I have missed VCORE on L7100 (page 59).... - Loading...
