Does anybody know where to get this SIM Card Holder?
  • GlennMueller
    • Jun 2015
    This Card Holder is used in the AVM Router FritzBox! 6840
    Also i found it in the Fujitsu Lifebook T935 Notebook.
    But i cant find this Holder at RS, Digikey or Mouser. It is shorter than the Part they sell.
    The Numbers Printed on the Part seem to be some kind of serial number as the different every Time.
    Any Suggestions where to find it?
    Thanks!!!
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: Does anybody know where to get this SIM Card Holder?
    hey here you got a solution :P http://www.mobilabredband.se/forum/t...te-router.html
    resuming you can use any card h9lder , you just need to make some adaptation
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      https://www.lteforum.at/mobilfunk/hu...62/#post-75095
      • Christos Tsiligiannis
        Marian Trace Alpha sound card repair help
        by Christos Tsiligiannis
        Hello to the forum.
        My name is Christos, I am new to the forum here and i am posting from Greece.
        So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
        To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
        So i tried asking for a schematic from the company and they would not give me one. Instead they...
        11-18-2024, 05:26 AM
      • Kemer
        Graphics Card mounting frame
        by Kemer
        Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
        As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
        I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
        What worries me right now is the possibility that...
        09-14-2024, 08:57 AM
        HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
        This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
        09-06-2024, 08:30 AM
      • FZG
        EVGA Nu Audio Sound Card - Not Working
        by FZG
        I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
        The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
        I found...
        03-07-2025, 11:44 AM
      • benwaterson
        Gigabyte Aorus 1080ti - card not initialising
        by benwaterson
        Hi there.
        Have searched various forums but haven't come across the exact issue I am having.
        Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
        I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
        Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
        02-05-2022, 11:42 AM
