Acer la-5892p motherboard charging problem
  • sanjayajungthapa
    • Jul 2015
    • 31
    • Nepal
    acer charges for a minute and then charging is gone. Operates in Battery only.
    which mosfet might be faulty?
    Again charges for a minute unless we eject the battery and insert it.
    Help Plzzz...
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Acer la-5892p motherboard charging problem
    Must be working on charger?
    And battery
    But not charging
    i would replace battery with a good one and test.
    • sanjayajungthapa
      • Jul 2015
      • 31
      • Nepal
      And battery
      But not charging
      Works Individually on battery and charger.
      Battery Changed ISL6257, 4407a ichips also changed. No Progress
      Works Initial bit but after a minute or so, operates from battery only.
      • razu
        • Jan 2015
        • 218
        • Bangladesh
        Check 19 volt in mosfet and battery charging voltage out mosfet.................
        • sanjayajungthapa
          • Jul 2015
          • 31
          • Nepal
          Initially all voltages are ok 19v. Later On, shows 12v relative only at the voltage load.
          • CPUFiddler
            Acer Nitro 5 AN515-45 not charging
            by CPUFiddler
            Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
            This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
            I've downloaded...
            03-19-2025, 07:44 AM
          • titomno2
            Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
            by titomno2
            Hi guys,
            I currently trying to figure out why the laptop of my friend did not charge.
            It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
            At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
            I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
            My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
            06-11-2024, 11:52 AM
          • titomno2
            Acer Nitro AN515-42 Not Charging
            by titomno2
            Hi guys,
            06-11-2024, 02:54 AM
          • gfosterCA
            Acer Aspire 5 N20C5 - no power, not charging. Motherboard FH5AT LA-K091P
            by gfosterCA
            Good afternoon all.
            After verifying 19V source and testing for short on the DC charge jack, kept hunting..
            Pin 5 of PQB3 shows 19V.
            Pin 4 of PQB3 seems to from 0.3V down to 0, and repeat.
            Pin 1-3 of PQB3 sit around 0.03V down to 0.
            _____
            Pins 5+ on PQB4 appear to be shorted to ground.
            Voltage injection shows inductor PL501 and PU501 getting hot.
            For kicks and giggles, removed the inductor PL501, and short at PQB4 is no longer. Would stand to reason that it's on the side of PU501. Side effect: battery...
            02-10-2024, 02:55 PM
          • malogro
            Acer Nitro 5 (EH5VF motherboard) all works except battery charging
            by malogro
            Another puzzle if you are so inclined. Attached PCB/Schems.
            Background:
            This unit came to me as "no power". Simple visual inspection revealed a blown up PQB11. I replaced it along with PQB12 just out of standard procedure of replacing them as pairs, and even though it fought me tooth and nail I was able to get a new one in and the board booted fine first try after that.
            I've since tested the laptop to boot and even stress tested; no issues whatsoever. However, battery won't charge. It will work off the battery no problems...
            05-30-2023, 01:58 PM
