HP 6540b fan not working when charger disconnected
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    So, fan is working fine if the laptop has not booted into anything (like windows or LiveCD) if the charger is connected. When disconnected, it just stops.
    And looks like it is barely working when it has booted and charger is connected.
    Although it is 6540b, BIOS says it's 6440b and because MPM is locked, I can't replace it with correct data with DMI tool. But since 6440b and 6540b BIOS is the same, it should not be the cause of this problem.
    Have tried with other working fan, still the same problem.
    Any more ideas?
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: HP 6540b fan not working when charger disconnected
    Any more ideas?
    post your old bios and dmi data, csn, sku
    maybe i can fixed..
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Thanks for the offer but I just removed the control pin from the fan so it's always @ 100% and gave it back. Atleast it's better than an overheating laptop.
      • baglaivlad
        A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
        by baglaivlad
        Hello everybody!
        Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
        After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
        11-20-2024, 08:14 AM
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
        HP ProBook 6440B 6540B Laptop Schematic
        LA-4892P...
        10-13-2024, 05:00 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
