lenovo G470 no power.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    Re: lenovo G470 no power.
    Originally posted by rickybucalan
    thank you very much " BOYEBARAN" !!!!
    I got it. its working now...
    put a jumper wire from switch to d23 pin 2.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Powderfanupnorf
      Dell AL440LX power on switch circuit help required
      by Powderfanupnorf
      Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
      So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
      My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
      06-24-2024, 01:24 PM
    • grimacelord
      NEC TurboExpress On/Off Power Switch Replacement Help
      by grimacelord
      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
      11-09-2023, 09:49 AM
    • Mufasa
      Lenovo Yoga 6 Power Switch Board Parts Identification
      by Mufasa
      Hey peeps,
      I have a Lenovo Yoga 6 with a smashed in switch module. All I need is a replacement switch and not the entire board. Does anyone know a likely candidate from another Yoga laptop or a vendor who most likely has the replacement needed? ...
      10-18-2024, 06:28 PM
    • Dr.d
      Help please..Lenovo ideapad 5 14itl05 power and charging problem
      by Dr.d
      I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
      Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
      04-05-2024, 11:48 AM
