lenovo thinkpad w520,shorted,replaced kbc, beep 1-3-3-1
  • PokickTheN00b
    • Oct 2016
    • 12
    • Poland
    hello all
    propably in my falaut docking station has shorted or even maybe reversed polarity
    after opening laptop i noticed that kbc r4f2113 h8s 2113 is broken(burnt)
    i got new one and replaced it, then trying turning laptop on i hear beep code
    1-3-3-1 what means bad ram or MB problem , change of differ rams got noting
    I asking for any clue or help
    i add schematcs i found, where i can find components value such as resistors ?
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: lenovo thinkpad w520,shorted,replaced kbc, beep 1-3-3-1
    Make sure you check every pin of the kbc, you replaced to make sure it is connected to the board properly, last time I changed a kbc for hp and after it gave me error blinks like processor error, after resoldering correctly everything was ok
    • PokickTheN00b
      • Oct 2016
      • 12
      • Poland
      yup thanks for anwser gotta check it tomorrow,thus dont i have to program it ? that chip is programable
      • PokickTheN00b
        • Oct 2016
        • 12
        • Poland
        sorry for delay ->i have broken my magnifier,but got new one now
        I have chcecked kbc its soldered pretty well,instead as i feared R406 (nearby of kbc) was kinda broken in half so i decideted to mesure it, resistor is bad how to replace it now, i dont know value of it and cannot find it on schematic, btw when i pluged one ram in top slot on top of MB laptop was restarting itself like looking for bootable device but having 4 slots filled got me 1-3-3-1 beep
        Thanks for any kind of help
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          Originally posted by PokickTheN00b
          ...............i dont know value of it and cannot find it on schematic..
          Use "Find" tool in your pdf reader. you'll find it
          would be help if you take photo near KBC chips (Resistor issue) clear and not blur..wistron platform have code mark on board, give me the code.
          according from pdf, DY means there is no resistor on it. I doubt, may be this other version of wistron kendo
          • PokickTheN00b
            • Oct 2016
            • 12
            • Poland
            when trying to remove resitior with hotair i noticed that pad is moving so i taken it off but propably i can solder R to the track,
            here are photos ...
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              Your pdf was correct kendo-3 ws (work station)
              I upload pics with pin out and mark. Seem It's R363 (value 10K)
              square mark with yellow if you mean is that resistor
              Then need confirm if that correct!
              • PokickTheN00b
                • Oct 2016
                • 12
                • Poland
                after soldering 10k Resistor into place and placing 4x4gb rams , laptop still beeps the same error ...
                • meritosari
                  • Oct 2010
                  • 774
                  • Indonesia
                  Unfortunately I don't have experience with lenovo like this.
                  any other symptom? like loop restarting as well
                  • PokickTheN00b
                    • Oct 2016
                    • 12
                    • Poland
                    when i plug power, fan and power light go up for a second, then i need to hold power button for longer than usual after it, laptop turns on got beep code and stays up
                    • PokickTheN00b
                      • Oct 2016
                      • 12
                      • Poland
                      isnt that kbc programable ?
                      • meritosari
                        • Oct 2010
                        • 774
                        • Indonesia
                        Have no idea, H8S/R4F2112, this is first time I see it on schematic.
                        On slot ram this signal should check too.
                        As reference :
                        https://www.badcaps.net/forum/showpo...46&postcount=3
                        I fear this not only DRAM problems, since you must hold power button to power on laptop.
                        • PokickTheN00b
                          • Oct 2016
                          • 12
                          • Poland
                          may that schematic wrong ? chip i got replaced is h8s 2113 not 2112
                          • meritosari
                            • Oct 2010
                            • 774
                            • Indonesia
                            probably yes, I don't have any refer to answer the question. only one thing, this series have many variant. I mean kendo-1, 2, and so
                            There are a bit different if comparing with your photo
                            here the BV that I've got.
                            on vinafix site, have more than I having. but I don't have access into it (pay site)
                            • PokickTheN00b
                              • Oct 2016
                              • 12
                              • Poland
                              i have looked for another schematics but everybody want me to pay for it, guess i have to pay and share it for badcaps comunity
                              • meritosari
                                • Oct 2010
                                • 774
                                • Indonesia
                                I've forgot to mention it, open the BV with
                                boardviewer by remax
                                https://www.badcaps.net/forum/showthread.php?t=56989
                                or
                                openboardview by inflex
                                https://www.badcaps.net/forum/showthread.php?t=56151
                                • PokickTheN00b
                                  • Oct 2016
                                  • 12
                                  • Poland
                                  when i gave mb just one ram it starts to reset over and over
                                  no ram = 1-3-3-1
                                  ram in top port under kayboard and left port when fliped on back or both gives no beeb but it keeps restarting
                                  giving ram to other ports equals getting same beepcode
                                    Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-06-2024, 11:40 AM
