Dell inspiron 3521 Power Problem
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Hi friends,
    I checked the mobo but +VCC_CORE and +VCC_GFXCORE_AXG not coming. Is anyone having same experience ?
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Dell inspiron 3521 Power Problem
    I need the boardview for this mobo. Can any person sharing with me ?
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      What board do you have...what are the symptoms? No display or something else ?
      Do you have 3.3v and 5v first ?
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        Board is LA-9104P 3.3V not coming 5V also
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          Lets start with schematic
          • Djosla
            • Dec 2012
            • 246
            • Montenegro
            So your machine is completely dead ??? first put laptop on ac charger,measure this and post:
            1. B+ voltage on PR102
            2. pu200 pins: 1,6,13,16
            After that remove charger and measure resistance to ground :
            3. pr102
            4.PL200,PL201
            • raajkumar
              • Mar 2015
              • 354
              • Srilanka
              I need Boardview Also for this. Anyone having please send it to me.
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                Today for this platform, have no boardview (may be confidential)
                • HarryPK
                  • Mar 2014
                  • 212
                  • barabai
                  it is true, the file is very confidential
                  • Djosla
                    • Dec 2012
                    • 246
                    • Montenegro
                    you don`t need board view almost everything is labeled...
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      I would check the RTC Battery Voltage. If that were not good then I would put in a new battery and flash the bios once again.
                      • raajkumar
                        • Mar 2015
                        • 354
                        • Srilanka
                        RTC Battery Voltage is OK. I checked at JP12 and its coming 3.02V But i can't see +3V Pgood and any 3Voltage from any point of this motherboard.
                        • raajkumar
                          • Mar 2015
                          • 354
                          • Srilanka
                          I checked PQ202. it shows 19.6V at the input but it is not giving output so i checked it but its working. now i have doubt on PU200. Is there anyone having any ideas?
                          • meritosari
                            • Oct 2010
                            • 774
                            • Indonesia
                            My idea is that you must follow advice on post#6
                            • raajkumar
                              • Mar 2015
                              • 354
                              • Srilanka
                              3. pr102
                              4.PL200,PL201
                              When i am measuring PU200 pins: 1,6,13,16 something happened by mistake it was short circuited and it was burnt. thereafter i removed PU200 and checked PQ101 also short circuited. i removed PQ101 and PU200 chips. Now i measured resistance to ground on PR102, PL200 and PL201 it shows, PR102 and PL201 shows 0 ohms and on PL200 shows 0.834K ohms.
                              • meritosari
                                • Oct 2010
                                • 774
                                • Indonesia
                                What kind of test leads do you use for probing small IC?
                                https://www.badcaps.net/forum/showth...obe+multimeter
                                • raajkumar
                                  • Mar 2015
                                  • 354
                                  • Srilanka
                                  Actually i am using Sanwa CD800a DMM.
                                  • aanan
                                    • Dec 2010
                                    • 222
                                    • India
                                    +3v power good signal pu 200 pin no 23.
                                    • meritosari
                                      • Oct 2010
                                      • 774
                                      • Indonesia
                                      First, you have to dig many information before doing anything that you don't know how to do it. BC/badcaps.net have a lots "case study", informations, use to increase your knowledge.
                                      in this case, I worry may be currently your probes are original from packages, not really sharp, best Idea using probes sharp point.
                                      Originally posted by SteveNielsen
                                      It takes good eyes and a steady hand. There's no doubt about that.
                                      Make some prepare, hold your breath to avoid shaking while probing. Test contiunity around the IC there which connected to Cap or Resistor and put them as your test point, not direct to pin the IC
                                      • raajkumar
                                        • Mar 2015
                                        • 354
                                        • Srilanka
                                        I already replaced the meter probes as thin like needle. That is not the problem. This happens by-mistake. There are some SMD components nearby to PU200 without component ID. That's what i asked Boardview. But now i fixed this by replaced PU200 and PQ 101. Now its working fine. Thanks to everyone to helping me to fix this.
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
