HP Probook 4510s keyboard removal
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    I've looked at Youtube videos of 4510s disassembly, and at HP's instructions namely:
    http://h20464.www2.hp.com/resultsCSR...4-CBFF7FB56D76
    Before you begin: Remove the battery and switch cover.
    1. Remove the two 5mm P1 Phillips-head screws that secure the keyboard to the top cover.
    2. Slide the keyboard toward the rear of the notebook to release the retaining tabs.
    But I cannot budge the keyboard, even though I have definitely removed its two screws
    Any tips ?
    The videos/instructions make it look so simple
    What could be holding it in place ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: HP Probook 4510s keyboard removal
    I had the same, lift and slide up at same time had tape stuck.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Thanks, suspected something like that
      But I was too scared of something breaking to try lifting very much, so gave up idea of SSD upgrade and just put it back together
      • sopik78
        • Nov 2013
        • 517
        • Czech Republic
        There are 6 or 7 screws under the battery at least, remove it and even than you can remove that cover.
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Had already removed those 7 screws then the switch cover, to be able to access & remove the two screws securing the keyboard
          • sopik78
            • Nov 2013
            • 517
            • Czech Republic
            Ok, so it's almost done. Now just use some power and push the keyboard to the screen, sometimes it goes hard, but you shouldn't damage anything.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Yes, slide keyboard up towards the screen and it will come off. There are no screws underneath, it's just the two (4510) or three (4710) on the top side.
              A working TV? How boring!
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                There are two holes in the bottom of the laptop , located under the removed covers , where you can push the keyboard up gently . Once you done it with a thin screwdriver , it will be easy to grab it from the up side ..
                • cyberhack
                  • Feb 2013
                  • 466
                  • Uk
                  If all the above dont work then use the best tool ever.
