I have a problem with this laptop when I plugged in the charger blue light comes then shuts off but when I putt the battery it charges in and when I remove the battery and press power again blue light standby no cpu fan spinning. I already measure dc jack 19 volts is present I measured some of capcitors 3.3 and 5v are present but I notice the chip ATI IXP 460 is hot. please anyone can help me.Ive attached the image of ATI. thank you
					Ecs elitegroup w341ui
			by rex98hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
maybe you could help me how to shift these resistors to disable its onboard ram.
this is is the presents and not presents... -
			by valente222I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
n, please identify.
330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
...06-27-2024, 06:11 PM -
			by air_chair256Hello,
I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
Tried to reball RAM 1,2,3,4
Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button... -
			by javieromexHello, any help will be apprecited!
- Model: Dell G15 5511
 - MB: LA-K452P
 - Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
 - Customer reported it was turned off and left plugged in during the night and thats it...
 - No signs of liquid damage or burned components.
I have checked so far:
			by ProttHello fellow Badcappers,
I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what... - Loading...
