IC LAPTOP Richtek Code pdf
  • ahsi19
    • Jul 2016
    • 28
    • egypt
    all Richtek Code pdf
    all ic Richtek
  • coelectron
    • Mar 2014
    • 61
    • Argentina
    Re: IC LAPTOP Richtek Code pdf
    thanks friend
    • RdeveLabs
      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
      by RdeveLabs
      To all the members here...
      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
      05-05-2025, 04:59 AM
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
    • Sanjit Keskar
      Laptop mouse & KB NOT available on power option restart but available only when laptop is cold booted using power button
      by Sanjit Keskar
      I have this inexplicable problem from yesterday
      Each time i start my laptop by pushing the physical power button in, the laptop keyboard and touchpad are available to me for use when the system has booted to the desktop (I can enter the bios by pressing on F10 too) irrespective of whether the laptop is powered by the AC adapter or the battery. This is normal behaviour
      BUT NOW FOR THE ABNORMAL PART
      However, when using the laptop normally, if i choose restart from the power options, the touchpad and mouse are non-functional when the system has booted to the...
      06-06-2024, 10:35 AM
    • floodster1
      Need help with msi laptop rtx 3080 code 43
      by floodster1
      Bought an Msi laptop with rtx 3080.
      when i got home and turned it on the card has code 43.
      seller wont respond so I'm forced to try and fix it.
      i did some probing around and there's no shorts on the memory rail, samsung memory at 37 ohms which seems good for samsung memory.
      the problem is I'm new to mats/mods.
      I'm looking for help on what version and command's i need to run it as a secondary card on the laptop.
      could anyone give me some guidance.
      thanks!
      03-12-2024, 06:17 PM
    • yomama07032
      Microsoft Surface Laptop 3 (1868) won't turn on
      by yomama07032
      I have a Microsoft Surface Laptop 3 (1868) - 13.5 inch. It is the version with the i5, 8 GB of RAM, and 256 GB SSD. I believe the motherboard number is M1098028-008. It has been dead for a year and a half. I tried everything that is suggested on Microsoft's support website. I have the original power supply, and the white light on the power supply's connector turns on and stays on when it is connected to the laptop. Nothing happens when I try to turn on the laptop. The caps lock key's light does not turn on. There is absolutely no sign of life. I have also tried charging the laptop using the USB-C...
      11-01-2024, 05:25 PM
