Macbook pro 820-2849-A
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Hi i m working with this macbook .
    Some time start normaly boot ok all function .
    Many times not power up ,green light on charger but not power up.
    Disassemble laptop and i find chip graphic Nvidia go to hot when i plug magsafe, when start ok chip stay normal temperature (not to hot).
    -Flashed Bios
    -Reballed chip nvdia
    -Changed dc jack to.
    So what do you think maybe chip is to replace or...?
    Any idea please
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: Macbook pro 820-2849-A
    so GPU get very hot after DC jack insertion ????? or become hot after turning on machine ??!?!?!?
    • gcomputers
      • Apr 2013
      • 509
      • Albania
      Yes Gpu go to hot after jack inserted.
      In this case the machine not turn on.
      But when i plug/ unplug jack sometimes the machine start ok and gpu its on normal temperature.
      • gcomputers
        • Apr 2013
        • 509
        • Albania
        any idea?
        • alihomee
          • Dec 2012
          • 1594
          • malaysia
          just change gpu will be all right
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • Loki_Fido
            Requesting help identifying chip in Macbook Pro A2485
            by Loki_Fido
            Hi ya folks,
            I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
            It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
            I replaced it and the SSD are fine. No more shorts.
            But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
            But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
            Chip marking...
            08-07-2025, 10:17 PM
          • SSBDADC234
            MacBook Pro 14". The screen DP chip failed.
            by SSBDADC234
            When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
            However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
            Testing the chip pins with a multimeter revealed a short circuit inside the chip.
            Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
            04-19-2024, 08:51 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
