Lenovo G50-30 no display
  • cholski1
    • Mar 2016
    • 15
    • ksa
    Can anyone drop a schematic diagram for lenovo g50-30 here? this unit has no display, i already reflash the bios, no luck.
    thanks.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Lenovo G50-30 no display
    Here you go.
    I have one of these i am working on. I had to get a special programmer for the kbc.
    • cholski1
      • Mar 2016
      • 15
      • ksa
      thank you sir
      • thodoris10
        • Mar 2014
        • 17
        • Greece
        Do you find any solution? I have the same problem, i reflash the bios but nothing. I think it is probably bad processor.
        • onzey
          • Oct 2016
          Is it booting to external display?
          Recently worked on a Lenovo G505 which has weird issue. I new it was booting by using an external monitor but laptop screen was blank.
          Only way to get correct boot so that laptop screen display is visible (including Lenovo splash screen, and incidentally, the webcam to be recognised correctly in device manager) is to press power on button and immediately close the laptop lid and reopen it.
          • memoslar
            • Apr 2015
            • 122
            • Greece
            Originally posted by diif
            Here you go.
            Was the Kbc or the cpu processor??
            • f-bone
              • May 2013
              • 96
              • Greece
              same here - we replaced the CPU (it was shorted) and also flashed BIOS and EC.. still no image. Laptop turns on, all power rails ok..
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                Which pin of the CPU was shorted?
                How did you measure the BGA pins?
                • f-bone
                  • May 2013
                  • 96
                  • Greece
                  I didnt measure the CPU itself - I deducted that from 1.8VALW being shorted at PJ602. I then measured around and noticed that the CPU power rail was also shorted. Replacing the CPU removed the short and the system now powers on with voltages at all rails.
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    now you have to trace signals on the motherboard to see which one is not present.
                    • subroto
                      • Oct 2015
                      • 230
                      • Bangladesh
                      Change the KBC and reflash KBC with same EC BIOS by SOVD or similar programmer. Hope your problem will be solved. Can you feel a little heat on KBC during running?
                      • f-bone
                        • May 2013
                        • 96
                        • Greece
                        hi guys and thank you for your input - I tried a new KBC (flash it with Vertyanov) and it does the same - I think it gets a bit warm, too. Unfortunately the customer is impatient and I had to return it. We will solve this G50-30 maybe next time!
                        again thank you.
                        george
                        • hardware-tec
                          • Aug 2017
                          • Argentina
                          Hola !!! yo tambien tengo una G50-30 que no da imagen. Enciende el led de encendido pero nada por pantalla,externamente tampoco me da imagen.Regrabe BIOS y sigue igual.Sospecho del procesador.Tambien al conectar el Cargador enciende sola la maquina.Ya me tiene medio loco jaajja...Si alguno me tira alguna info se lo agradeseria.
                          • hardware-tec
                            • Aug 2017
                            • Argentina
                            Hello !!! I also have a G50-30 that does not give an image. Turns on the power LED but nothing on the screen, externally it does not give me an image. It reads BIOS and it's still the same. I suspect the processor. Also, when the Charger is turned on, it turns the machine on. Info would be pleased.
                            • mauda
                              • Mar 2016
                              • 24
                              • Czech republic
                              Hello, have you solved it. I have a very similar problem. When the motherboard starts, it takes only 0.25 Amps. So I think, the motherboard did not post.
