MSI U250 no diaplay
  • kingchristo
    • May 2016
    • 20
    • Uk
    MSI U250 no diaplay
    Hi everyone I have a MSI laptop it boots and lights come on but there this nothing on the screen its just black
  • sopik78
    • Nov 2013
    • 518
    • Czech Republic
    Re: MSI U250 no diaplay
    Probably RS880 failure, reball it or change.
    • kingchristo
      • May 2016
      • 20
      • Uk
      I think it could be something with the bios but carnt find any way of clearing it or a schematic for this laptop to identify the bios
      • sopik78
        • Nov 2013
        • 518
        • Czech Republic
        I am pretty sure it is a NB problem, but you can try your luck.
        • JJR
          • Mar 2013
          • 171
          Are you sure it's not just a faulty LCD?
          • kingchristo
            • May 2016
            • 20
            • Uk
            Don't think so and the model is u230 not u250 my mistake
            • JJR
              • Mar 2013
              • 171
              Have you tried an external monitor or a known working lcd screen? I would try all the basic stuff first.
              • sopik78
                • Nov 2013
                • 518
                • Czech Republic
                Altough it's U230, the main problem is still the same - IGP AMD, RS780 in this case, so reball or change 216-0674026. You should do that long ago.
                • kingchristo
                  • May 2016
                  • 20
                  • Uk
                  Tryed a reflow but now it doesn't turn on just a quick blue light flash think its for the bin gud job it a laptop I got to test with
                  • Francesc V.
                    Christmas lights - Something I am doing wrong
                    by Francesc V.
                    Hi:
                    i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
                    I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
                    If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
                    Could...
                    03-11-2023, 07:38 AM
                  • pepebmx
                    ThinkPad T14 Gen 3 - Boots Only on Charger
                    by pepebmx
                    Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
                    Laptop: Lenovo ThinkPad T14 Gen 3
                    Serial No: PF-437QTG
                    PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
                    Extracted BIOS: Will upload tomorrow
                    BIOS Password: None Issue Description:
                    • Boots only on charger → Works normally when connected to AC.
                    • With battery connected:
                      • Fan spins at full speed, no display.
                      • Not all voltages present (some missing).
                    • Battery charges correctly (detected in Windows, shows percentage).
                    • When battery is plugged in while in Windows:
                      • Laptop shuts
                    05-08-2025, 01:53 PM
                  • bialag
                    Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                    by bialag
                    I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                    Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                    03-25-2025, 05:56 PM
                  • gabrielA7
                    IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                    by gabrielA7
                    Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                    I saw that the room LED lights up only when the screen is connected, so quiet.
                    We have all the power supplies, even processor, 1.8V
                    One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                    I suspect that there may be some leak in the processor.
                    Anyway, when I press the power, it...
                    10-29-2024, 06:48 AM
                  • lukkihapsi
                    Asus Vivobook X515JA Weird Boot Issue
                    by lukkihapsi
                    Asus Vivobook X515JA Laptop
                    Issue :
                    Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                    Tried :
                    Cleaned inside for dust, applied fresh thermal paste. No Change!
                    Removed keyboard, Trackpad, fingerprint sensor. No Change!
                    Removed Internal SSD. No Change!
                    Updated BIOS to latest version. No Change!
                    Removed battery and pressing power button for 1 minute. No Change!
                    Weird Part :
                    Upon turning laptop ON, screen lights up - stays black,
                    I...
                    07-07-2025, 12:07 PM
