Lenovo E530 power issue
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    I got this Lenovo from a customer yesterday, the problem is that it won't display with battery in, it will only display when plugged in, its boots up fine when plugged in with battery but won't charge the battery. I need help solving this very quick.
    Any ideas?
  • JaroTech
    • Mar 2015
    • 351
    Re: Lenovo E530 power issue
    Hi, do you have a voltage on both sides of the coil PL201?
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      There is power at both sides of PL201, the problem is not that it does not power on with battery, it powers on with battery but does not display with battery
      • JaroTech
        • Mar 2015
        • 351
        So, if I understand, if you connect an external monitor and boot with the battery, you have nothing on the laptop screen, but on the external you have a picture.
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • claws77
          lenovo flex 5 14itl05 power sequence issue
          by claws77
          hi guys, my motherboard will not start no matter what
          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
          but rest nothing happens no sign of life.
          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
          i have no knowledge of motherboards ....
          10-20-2024, 02:48 PM
        • justice171
          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
          by justice171
          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
          1. Verified that all critical voltages are present:
            • 3.3V and 5V are always present if DC is plugged.
            • 1.8V on the BIOS chip is present.
          2. Checked the power button functionality:
            • When pressed, the voltage drops to 0V, indicating the button is functional.
          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
            • Confirmed connectivity is intact, ruling out issues
          11-26-2024, 12:39 AM
        • yaya3gmax
          Laptop Power Issue – Works on Battery, Fails on Adapter Load
          by yaya3gmax
          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
          Symptoms:
          • Laptop works normally on a pre-charged battery.
          • Battery does not charge when adapter is connected.
          • Without battery:
            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
            • Speakers “pop” when power cut occurs indicating harsh sutdown.
            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
          08-21-2025, 07:16 AM
        • hendeky
          Lenovo 15IMH05 Power Issue
          by hendeky
          I have a problem with my laptop. I just short circuit the eDP cable by an accident. Then i try to open it. i press the power button it was powered the rgb keyboard but after a few seconds and it just shut down. When i opened it up and unplug everything from motherboard i can't see any physical damage from ICs, capacitors and MOSFETs. I found a broken fuse FG3. But it just powers up LCD Display. I try to power it on with DC Adapter and feel some heat from an IC. IC is repeatedly power on and off. I tracked the schematic and i found some MOSFET and main 5V/3.3V controller. After that i...
          03-23-2025, 11:45 AM
