fan running full speed
  • JJR
    • Mar 2013
    • 171
    I have just had a laptop come in with the fan running at full speed (very loud).
    The client says his son had it in the far east where a chip had been replaced on the motherboard, doesn't know which chip, doesn't know why.
    It's a HP Pavilion G6-1103sa. I had a look at the board and noticed a chip (APL5606) had pins 2&3 solder bridged. I cleared the bridge and the laptop now works perfectly.
    Question - would you deliberately bridge pins 2&3 on a fan regulator to make it spin at full speed? If not could the tech have replaced the chip and just done a bad solder job?
    What do you think?
  • JJR
    • Mar 2013
    • 171
    Re: fan running full speed
    Data sheet for the ALP5606 -
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Why it is bridge really does not matter. The fact that it is connected in a way that the designer had not intended is call for alarm. I think you need to undue this short and then we will be able to tell if it is simply a mistake or if there was a problem the technician could not fix because he had a problem he could not fix for what ever reason.
      • diif
        • Feb 2014
        • 6978
        • England
        Does the ALP5606 look like it was soldered on by a drunken half blind monkey ? If so it's probably a mistake. If the rest of the soldering looks neat it possibly a quick bodge to keep the fan faster and the laptop cooler (perhaps the original complaint/possibly it didn't have anything replaced at all).
        • JJR
          • Mar 2013
          • 171
          The chip was positioned perfectly square and all pins looked professionally soldered, with the exception of pins 2&3.
          The bridge was a large blob of solder (sorry, no pics) that I would think was impossible to miss if the work had indeed been done on that chip.
          So I'm thinking it must have been a bodge, but why, when the blob was removed everything was fine.
          Probably one of those unanswerable questions.
          • diif
            • Feb 2014
            • 6978
            • England
            Pin 2 is voltage in 4.5v-6v and pin 3 is voltage out, so effectively the chip and it's control has been bypassed with more than normal voltage sent to the fan. I think the fans are only 5v so it much have been screaming ?!
            • JJR
              • Mar 2013
              • 171
              Yes, it was very loud, the client had lived with it for a couple of months and reckoned it was making him deaf!
              While the fans was running permanantly flat out the CPU temp was 34c, once I removed the short it was running at 49c and upto 57c when the fan kicks in.
              • diif
                • Feb 2014
                • 6978
                • England
                I don't know how people can do bodges like that and be happy with themselves.
                At least it did the job I guess, lol.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  usually on some laptop as some hp models , the heatsink is not adeguate due to some bga (gpu or others) costruction issue. to prevent bga damage some technicians short two pins to change fan speed at maximum. If you remove this hack, it's possible to have a bga problem.
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    Is the fan maintaining the temperature under 57C? Sometimes if the fan is set to passive cooling instead of active cooling the HP seem to over heat. HP defaults out to passive cooling. This can be changed in the control panel in power plans. I also believe it can be changed in the bios.
                    • JJR
                      • Mar 2013
                      • 171
                      This is possible as a lot of HP laptops were susceptible to overheating, but I have not come across a remedy like this before.
                      • JJR
                        • Mar 2013
                        • 171
                        When the temp reached 57c the fan activated, when it dropped to 49c the fan stopped. The BIOS had the option to run the fan permanently, I disabled this option.
                        The client is now happy and has taken the laptop away. We wait to see if it ever returns
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          I would had enable that option as I have heard from more one than person that their units had overheated which cause the processor to fail. I actually work on one that was putting out a lot of heat and enable the fan to run actively. This then cured the heat problem. I also made sure that the minimum processor was set to around 5% to allow it to cool off when not in use or in a lower state of use.
                          • acedogblast
                            by acedogblast
                            11-02-2024, 05:13 PM
                            Common SPI bios chip programming Questions and Answers
                            by SMDFlea
                            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                            A: If you can`t read from it how do you expect to write to it ?.
                            Q: Why is my bios chip unreadable ?.
                            A: The programmer is faulty or has a worn or broken zif socket.
                            The USB cable is frayed,connector pins worn or some other physical damage.
                            Not enough amperage or voltage to power the programmer properly.
                            Bad...
                            09-02-2021, 04:40 PM
                          • BMCappelletti
                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                            by BMCappelletti
                            Long story short:
                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                            - gave the computer to his son a couple years later
                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                            (seems like the story was not that short)
                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                            01-08-2025, 07:27 PM
                          • Troystain
                            Help EZP2023+ updated chip database for w25q256jveq?
                            by Troystain
                            Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                            I need to add w25q256jveq chip but I do not know what data should I type.
                            I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                            The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                            11-25-2024, 12:53 AM
                          • inck243
                            Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                            by inck243
                            Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                            The BIOS...
                            07-25-2024, 09:17 AM
