CQ40 LA-4101P laptop video drivers fails and hangs
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Hi Techies
    I need you help, i have cq40 laptop in which display driver fails, there is not graphic card. Find me some solution pleeeeeez
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: CQ40 LA-4101P laptop video drivers fails and hangs
    Try to insall a fresh windows.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • japlytic
      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
      by japlytic
      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
      Tried (only with keyboard/mouse connected):
      • BIOS + database update
      • Using latest Windows 11 image built with official image creation tool
      • Previous setup version for Windows 11 installer
      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
      06-19-2025, 04:59 PM
    • pavithra
      LC6685 based LED drivers
      by pavithra
      I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
      I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
      Is it possible to get the datasheet of LC6685 IC?
      Also highly appreciate if you could let me know what could go wrong....
      04-16-2024, 02:46 AM
    • kuba2102
      Alienware m15 R4 CPU or CPU drivers issue
      by kuba2102
      Hi. I had a problem with this laptop that under a load it would crash the system, meaning the screen would go black and unresponsive. I have noticed that CPU drivers surrounding area of PCB has changed colour due to high temperature. I have tried to reball the Drivers, but after it laptop wouldn't turn on at all and it would trigger over current protection in the PSU. I ordered and replaced 3 of of 5 Drivers (3 CPU, 2 IGPU?), and it started producing 1.2V again but just for a second. I get led flashing out the CPU failure code. Now I'm not sure whether there is still a problem with the drivers...
      01-04-2023, 09:05 AM
    • kotel studios
      Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
      by kotel studios
      Finally got time to fix this board up.
      At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
      Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
      04-22-2025, 05:08 AM
    • YOUCEF4787
      Installation Issue with AMD Radeon 520 Graphics Drivers on Dell inspiron 15 3576
      by YOUCEF4787
      I am writing to seek assistance regarding a problem I encountered while attempting to install the AMD Radeon 520 graphics drivers on my Dell Inspiron 15 3576 laptop running Windows 10.
      Upon installing the graphics drivers, my system freezes, and I am left with a black screen. Unfortunately, this issue has prevented me from utilizing the full capabilities of my AMD Radeon 520 graphics card.
      Laptop Model: Dell Inspiron 15 3576
      Operating System: Windows 10
      Graphics Card: AMD Radeon 520
      Steps I have taken:
      Downloaded the latest AMD...
      07-08-2023, 05:23 AM
