I got this from a customer yesterday, I have read all voltages correct, 3.4v is present on switch and battery terminals, but when I press power switch nothing happens, I was thinking it could be a bios issue, can anyone help?
Lenovo T410 power issue
Re: Lenovo T410 power issue
I think s the bios, try to find a new one an flash it, of you can post the old bios here on the forum and ask plp to fix it.The Night Drop Down, I Will Keep Try Until..., You Never know.
Dushi Kòrsou, Nos Tei.Comment
Hi
I have also problem with t410 all power seems ok. 3v and 5v power is ok
But the laptop remain in bootloop when power up.
I check for probably short circuit but all voltage seems to power up
And immediatly shutdown. I have tested cpu in another computer and is ok.
Finaly i hope the bios file is corrupted. Please someone can give me a dump to repare my
Core i5 laptop.lenovo t410 type 2522.Comment
by claws77hi guys, my motherboard will not start no matter what
when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
but rest nothing happens no sign of life.
this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
but now nothing happens no matter how much i wait/ charge/ press and hold power button.
i have no knowledge of motherboards ....10-20-2024, 02:48 PM -
by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM -
Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...13 Photos06-24-2024, 01:24 PM -
by justice171I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:- Verified that all critical voltages are present:
- 3.3V and 5V are always present if DC is plugged.
- 1.8V on the BIOS chip is present.
- Checked the power button functionality:
- When pressed, the voltage drops to 0V, indicating the button is functional.
- Inspected the flex cable connecting the USB, audio, and power button to JUB1:
- Confirmed connectivity is intact, ruling out issues
11-26-2024, 12:39 AM - Verified that all critical voltages are present:
by yaya3gmaxDell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
Symptoms:- Laptop works normally on a pre-charged battery.
- Battery does not charge when adapter is connected.
- Without battery:
- Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
- Speakers “pop” when power cut occurs indicating harsh sutdown.
- If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
- Loading...
