lenovo e535 APU tempature
  • m4a2t0t
    • Mar 2013
    • 276
    Does this board have an external sensor for measuring APU temps?
    MOBO - LA-8124P
    Issue:
    The thermal sensor for the APU is reporting at 85C idle with an A6 APU. I replaced it with a A10 and it reports +90C at idle. The heatsink is cool so I know its not overheating.
    The problem is that the system is throttling the APU to 900MHz because of the temps.
    I thought the sensor would be internal to the chip. If the sensor was bad then replacing the chip should have fixed it.
    I have upgraded to the latest BIOS without any change.
    Thanks for any help
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Re: lenovo e535 APU tempature
    Check out the board schematic page 38.there is a thermal sensor near apu...
    Also check capacitors on remote lines of U2402...
    • m4a2t0t
      • Mar 2013
      • 276
      Only Alibaba has the part and I can't find any dead boards for parts.
      Anyone have a dead board with this sensor on it??
      F75303M_MSOP10
      Labeled on top of IC
      303M
      GHEA5
      • atsio
        • Oct 2013
        • 819
        • Greece
        The specific IC reports temp of ddr and vram to ec. I do not think this ic is your problem. There isn't an external sensor for the apu on the board. Probably your problem is software related. Check with a fresh install without drivers and updates.
        • m4a2t0t
          • Mar 2013
          • 276
          First thing I did was install windows on a different drive. I thought it was a Windows 10 issue so I installed 7.
          Installed a new mobo
          APU reports 85-105C
          APU runs @ full speed
          The new board has BIOS 2.08. I guess I can try to reflash the old board or downgrade the BIOS if possible.
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            So, with new board the problem remains ?
            New mobo + Apu = 85-105°C
            • m4a2t0t
              • Mar 2013
              • 276
              Still temp issue but the APU is not stuck at 900MHz anymore.
              the temp really isn't an issue because I know it not overheating. I thought the high temps were the cause of the APU being throttled to 900MHz
              • Agent24
                I see dead caps
                • Oct 2007
                • 4953
                • New Zealand
                Is the the thermal interface material OK? You're not putting too little or too much?
                Because if the temperature is reported as high and the heatsink is cold, it could be that the heat is not getting from the CPU to the heatsink.
                -David VanHorn
                • quic307
                  • Jun 2015
                  • 255
                  • Greece
                  Does anyone have kbc and bios for this motherboard?
                  • CapLeaker
                    AcuRite 5 in 1 temperature sensor replacement repair
                    by CapLeaker
                    Got a new victim:
                    AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                    A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                    B: stuck at some temperature and maybe updating once in 12 hrs or so.
                    Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                    04-15-2025, 01:32 PM
                    Lenovo 3000 Series Schematic
                    Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                    3000 C100 laptop with Braille keyboard
                    Lenovo 3000 C
                    C100, C200 - 15-inch XGA screen
                    Lenovo 3000 N
                    N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                    N500 - 15.4 inch screen.
                    Lenovo 3000 V
                    V100, V200 - 12.1-inch WXGA models
                    Lenovo 3000 G
                    G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                    10-04-2024, 06:05 AM
                    Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                    This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                    09-06-2024, 06:40 AM
                    This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                    09-06-2024, 06:06 AM
                  • derradji89
                    Need help Lenovo MIX 320-10lCR domaine name SERCOL
                    by derradji89
                    Hi everyone 🤗
                    I have a Lenovo MIX 320-10lCR computer.**
                    1. **Operating System**: Windows 10 ** Education** 64-bit.
                    2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                    3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                    4. **BIOS Chip Reflashing**: Currently,...
                    04-19-2025, 03:04 PM
