Sony keyboard
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Sony keyboard
    Hey Guys,
    I replaced the motherboard MBX-224 from a VPCEB2S1E (15,5") with the MBX-224 from a VPCA3S1E (14,1"),
    I had to re-locate the 2 (mouse) touch switches and the battery connector.
    The option is there on the board and it works fine.
    Now I have one problem left, which is the keyboard. The connector is on the same place, but the board does not accept the 102 keyboard. The numeric pas does not work and if you press numlock, the standard keys change and the numeric still doesn't work. This shows the system use to have 86 keyboard.
    Where can I change that? The bios have nothing on the keyboard and I can't find nothing in the system settings.
    Any ideas how to solve this problem are welcome
    Thanks in advance
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: Sony keyboard
    Which bios have? You need to install VPCEB bios
    • bicalov
      • Nov 2014
      • 294
      • Netherlands
      Re: Sony keyboard
      Thx for reply.
      Biosfile Sony = EP0000228463.exe, containing R0300Y8.rom (Bios) and K0300Y8.rom (EC)
      Sony lists this same file for both types of laptop.
      I can't install it, because system says it is already there. So I must do a recovery and I don't know the right procedure for that.
      I look in this site and MDL site and every machine is there, except the Sony.
      AndyP tool says EFI INSYDE bios.
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Re: Sony keyboard
        Originally posted by bicalov
        Thx for reply.
        Please send me a private message with serial, so i can check on sony database the right bios for your device.
        • bicalov
          • Nov 2014
          • 294
          • Netherlands
          Re: Sony keyboard
          That is done already
          • Pragmatiko
            • Jul 2013
            • 468
            • IT
            Re: Sony keyboard
            bios is correct, mybe you need to write DMI or exchange eprom from old board.
            • bicalov
              • Nov 2014
              • 294
              • Netherlands
              Re: Sony keyboard
              I don't know about writing DMI. I can exchange eprom from old board, so I will try that.
              • Pragmatiko
                • Jul 2013
                • 468
                • IT
                Re: Sony keyboard
                Exchange bios and eprom near chipset
                • bicalov
                  • Nov 2014
                  • 294
                  • Netherlands
                  Re: Sony keyboard
                  I did that and you will not believe it, nothing has changed, all the DMI data is the same and the keyboard still is not working.
                  Onliest change is that the Fan is running full speed all the time while the temp on HWInfo says Cpu 26 degr and GPU 35 degr.
                  • bicalov
                    • Nov 2014
                    • 294
                    • Netherlands
                    Re: Sony keyboard
                    I put back the eeproms and the fan problem is gone.
                    Now I think the setting has to be in the DMI or ME. If the DMI is located in the eeprom, it has to be the ME.
                    Any thoughts about this are welcome.
                    • bicalov
                      • Nov 2014
                      • 294
                      • Netherlands
                      Re: Sony keyboard
                      This thread is the start from the other thread for the M961 schematics.
                      So here I'm done, I updated the Bios, EC and ME region and that did not help,
                      I have to look for the solution in the hardware, for which I need the schematics for M961
                      board.
