MacBook Pro 820-3115 logic board has power but will not turn on.
  • mattpd
    • Oct 2012
    • 302
    A1278
    820-3115B
    No fan, no video, no chime. Nothing.
    Shorting power pads does not help.
    SMC bypass does not help.
    Mag safe is green.
    Voltages seem good so far.
    ppbus_g3h = 12.22v
    PPBUS_S5_HS_COMPUTING_ISNS = 12.22v
    PPBUS_S5_HS_OTHER_ISNS = 12.2v
    PP3V42_G3H = 3.505v
    PPVRTC_G3H = 3.343v
    PP5V_S5 = 4.94v
    PP5V_SUS = 4.9v
    PP3V3_S5 = 3.334v
    PP3V3_SUS = 3.34v
    PP3V3_S4 = 3.34v
    PP1V05_SUS = 1.05v
    Not sure where to go next.
  • dj_ricoh
    • 2073
    Re: MacBook Pro 820-3115 logic board has power but will not turn on.
    Bios?
    • mattpd
      • Oct 2012
      • 302
      Originally posted by dj_ricoh
      Bios?
      Best way to check? Just buy a flashing unit and flash a fresh copy?
      • mattpd
        • Oct 2012
        • 302
        I think I am having problems with PM_SLP_S4_L. It's not present when the power pads are shorted...
        • korben_dallas
          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
          by korben_dallas
          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
          MY QUESTION:
          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
          02-14-2024, 12:23 AM
        • ledbylight
          M1 A2337 Macbook - No Display, likely due to logic board
          by ledbylight
          Hi all!
          This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
          I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
          11-04-2024, 06:36 PM
        • defdjamel
          Solder won’t melt on MacBook 2021 logic board – need advice
          by defdjamel
          I’m trying to remove a component from a 2021 MacBook logic board, but I’m having trouble.
          https://www.electronicsdatasheets.co...s/tlv70733pdqn
          I’m using hot air at 480 °C with full airflow and good flux, but the solder paste is not melting.
          I know there’s a lot of thermal dissipation from the board, and I suspect the copper planes are absorbing most of the heat.
          Do you have any tips for this kind of board? Would a preheater help?
          Thanks in advance!
          09-05-2025, 08:56 PM
        • yuuki47
          A2681 M2 MacBook Air Dead Logic Board
          by yuuki47
          Hello...
          My sister purchased an M2 MacBook Air a year and a half ago. While she was using it a week ago, it randomly shut off and no longer powers on. There are no signs of life and not even the MagSafe indicator LED lights up.
          We took it to Apple and they disconnected the battery and tried a bunch of stuff before they declared the logic board "brain dead" and quoted us about £567 to replace it. Typical of them...
          eBay replacements run about £367 with the Touch ID sensor included.
          I did consider to probe the logic board for shorts...
          04-13-2024, 06:22 AM
        • envym
          MacBook Pro 2018 with Activation Lock
          by envym
          Hi everyone!
          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
          06-27-2025, 08:54 AM
