HP 15t-i100 processor problem
  • angel-boy
    • 550
    • Romania
    - first time was a bad capacitor and a mosfet from power , now the board is running but restart, or no image, i notice that the coil from processor is very very hot , and bad image on display , see photo
    the mosfet that i change from power was AON6414A , i replace that with something compatible.
  • dj_ricoh
    • 2073
    Re: HP 15t-i100 processor problem
    How many V does it pass on those coils?
    • angel-boy
      • 550
      • Romania
      1.77v , and i see that with laptop on , the nvidia is cold. no voltage see photo
      • angel-boy
        • 550
        • Romania
        any help ?
        • ubogdan
          • Oct 2015
          • 3
          • Romania
          Your laptop is running on Intel® Core™ i7-4700MQ Processor (6M Cache, up to 3.40 GHz) with Intel® HD Graphics 4600 which is enabled by default at boot time, that's the reason of no power supply on Nvidia graphics.
          If you stop the bios at POST with "break/pause" key and you still have bad image, then you should try with another cpu to see if it makes any difference. I guess Intel graphics is damaged.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3576
            • slovakia
            are not 1.77V too high for main processor power?
            • angel-boy
              • 550
              • Romania
              should be ~1.08 1.1
              • dante91
                • May 2016
                • Georgia
                what was the end for this story.
                i have similar situation.
                after changing shorted PCH with new one notebook started working but the same with CPU power phases, haves the same high voltage and very hot.
                maybe i need to change phase controller TPS51631.
                • Djosla
                  • Dec 2012
                  • 246
                  • Montenegro
                  1.7v is too high...i would replace inductor , mosfets and cpu pwm....also pay attention on cpu pwm feedback resistors...Also try different cpu before doing anything...
