MBX-216 Vaio laptop dead
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    i have that MBX-216 MOTHERBOARD completely dead.
    I've seen that from PU2 ic there are 5v but 3v are missing pag.23 of schematic
    On PQ8 pin 5:19v 1,2,3:0v 4:0v
    RVCC ON pin 27 U2 is 0volt. if i put an external voltage on pin 27 of U2 3volt of PQ8 are present, then i suppose RVCC ON is missing.
    Is RVCC ON generated from pin 11 of U18 ?
    I have replaced it but still 3 volt are missing.
    Any help please...
    Tks
  • dj_ricoh
    • 2073
    • uk
    Re: MBX-216 Vaio laptop dead
    Sony mbx are notorius for bad caps.
    Some of them with bad gpu chipset.
    Find the main coils and see witch one its shorted to ground.
    • dj_ricoh
      • 2073
      • uk
      My bet is if you lify up pl8 right side is shorted.
      Check that first and confirm what side is shorted
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        i found short cap on power board but still dont start.
        • dj_ricoh
          • 2073
          • uk
          again.
          they usually come in pair
          find shorted coils or any short to ground. refer to diagram not to be connected o ground.
          Some fets are connected to ground o discharge. So please find a reference point so we can continue .
          • max-power
            Dell E6540 laptop completely dead after dssasembly
            by max-power
            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
            03-24-2025, 08:49 AM
            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
            09-06-2024, 09:30 PM
            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 08:47 AM
          • RdeveLabs
            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
            by RdeveLabs
            To all the members here...
            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
            05-05-2025, 04:59 AM
          • Loli Popu
            DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
            by Loli Popu
            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
            12-13-2024, 03:28 AM
