About different laptop charger voltage.
  • predator0357
    • Jul 2014
    • 159
    • Israel
    Hi
    I have a laptop (toshiba A300) charger that states 19[V] and i have different charger with 19.5[V], and i did check the voltage on both of them n the differences is 0.45[V], so i thinks it doesnt matter if i use the 19.5[V] charger cuz its less the 5% different from the original voltage. am i right?
    • 31254
    Re: About different laptop charger voltage.
    you are right,
    but make sure the replacement charger can supply enough amps.
    • predator0357
      • Jul 2014
      • 159
      • Israel
      Originally posted by stj
      you are right,
      the differences in the AMPS are 0.61 less then 19[V] charger
      19[V] 3.95[A] original charger
      19.5[V] 3.34[A] other charger.
      So can i use the 19.5[V] charger?
        • 31254
        well i wouldnt use the laptop while it's charging, but just charging should be fine.
        • megaraider
          • Jul 2015
          • 307
          • Portugal
          Check the laptop label (underneath).
          There should be something like:
          "DC rating xxV y.yyA"
          If y.yy equal or less then 3.34A you're ok to use the replacement.
          If greater follow @stj advise.
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • HERETIK10
            Adaptable charger voltage for Clevo D901C laptop
            by HERETIK10
            Thanks in advance to anyone who takes the time to help me. Sorry for the quality of my English, I had to use a translator at times...
            I bought a functional Clevo D901C (Sager NP 92261) with its battery but without its power supply.
            So, I invested in a new LiteOn charger, advertised by an online seller as the right charger for my machine... BUT, according to the pinout (4pin + shell) of the charger, 1 and 2 are 20V / and 3 and 4 are grounded. When I measure pin 4 with the ground of the PC, I have 300kOhms, which seems to be confirmed by the electrical...
            11-08-2023, 04:24 PM
          • serious_electron
            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
            by serious_electron
            Hello Everyone!
            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
            06-28-2025, 02:57 PM
          • rutgerv
            Acer Swift 3 SF314-42 not powering up
            by rutgerv
            Dear all,
            For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
            The issue with the Acer laptop is the following:
            It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
            08-02-2024, 06:59 AM
          • Vampy_1110
            Modifying output voltage of an Old Dell laptop charger
            by Vampy_1110
            I'm trying to turn this old dell laptop psu into a variable power supply (5-19.5) as i have already modified a few power supplies before and now i want to do the same with this but it's a bit complicated
            The pic below has an op-amp ic (Z103WA) that does the CC/CV adjustments and a double diode 3 pin ic at the far right
            As you can see there's no TL431 or Switching ic self-regulations that i can tweak easily.
            Any help would be appreciated
            02-12-2024, 03:17 PM
