Hp Pavilion 15-P AMD A10 overheating
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Hi the laptop shutdown after 10 sec due to overheating CPU ,what cause to processor get so hot so fast .What should I have to look new bios or power voltage short
    thx
  • dj_ricoh
    • 2073
    • uk
    Re: Hp Pavilion 15-P AMD A10 overheating
    try first a reball or maybe just a reflow ??!?!?
    they are soldered to the board right? if not the cpu socket can go dudu because of non cleaning and overheating
    • ciki
      • Aug 2014
      • 132
      • Ireland
      thx for suggestion I just want to mention that board when is cold start and you can see the bios but and then holds up to maybe 5 min but then get fan start loud spinning and turn off after that if u want to start holds only bios screen 10 sec and turn off (clean everything ,new paste on cpu) What else can cause cpu to get hot so quickly if not soldering connection on board
      thx
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        thx
        Is the heat sink actually making contact with the CPU? When i re did my CQ57 i had to shim the CPU to the heatsink with a penny that was flattened by a train because it wasn't making contact. That's the reason they used a toad skin thermal pad instead of some crap white thermal paste.
        Follow the white rabbit.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          u can have broken heatpipe
          • ciki
            • Aug 2014
            • 132
            • Ireland
            I thought same but then I put my finger on cpu and start laptop its get really fast too hot.Burns the finger (
            • ciki
              • Aug 2014
              • 132
              • Ireland
              Yes they are soldered to motherboard
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3577
                • slovakia
                u must have high temp on radiator. if u have temp on cpu and not on radiator u have broken pipe
                • ciki
                  • Aug 2014
                  • 132
                  • Ireland
                  I have temp spreading to the pipe and air blow from fan is warm
