acer aspire 4743 no power pwm overheat help urgent
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    hy friend I have acer aspire 4743 which pwm ic is over heat Ic number rt 8223 . I change the pwm new one but same, dc power supply ampare is 0.83. Its 5v coil supply is ok bu 3.3v coil is only 0.65v. but there is no short (mosfet,pf)
    what can I do
    mb part number is : JE- 43 MB
  • HarryPK
    • Mar 2014
    • 210
    • barabai
    Re: acer aspire 4743 no power pwm overheat help urgent
    what does happen when you pressed power button? previous/early
    • megaraider
      • Jul 2015
      • 307
      • Portugal
      You have to find who is to blame... step by step.
      If some IC is overheating it will most likely the one to blame (NOT the RT8223).
      If a visual and temperature inspection does not raise any suspicions,
      then you must follow a more step by step approach:
      - open the jumpers after '3D3V_PWR' (remove solder)
      - measure if RT8223 is outputting 3.3V:
      ยป if not, the mosfet are likely damaged...
      ยป if yes, you have to selectively follow the 3.3V circuit until you find the culprit...
      (ALL IC's connected to '3D3V_S5' are considered possible targets! Even the WiFi card among many others. Thus removing slot inserted boards might help reducing the possible culprits)
      • HarryPK
        • Mar 2014
        • 210
        • barabai
        i agree with Mega
          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
          09-12-2024, 03:28 PM
          ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
          This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
          Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
          This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
          09-06-2024, 05:27 AM
        • DenK
          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
          by DenK
          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
          12-06-2024, 01:29 AM
        • Bonaventure Vigil
          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
          by Bonaventure Vigil
          Dear All,
          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
          12-12-2024, 10:22 AM
