Acer 5742G dead after stress test
  • sopik78
    • Nov 2013
    • 519
    • Czech Republic
    Re: Acer 5742G dead after stress test
    What a magic trick is this?
    • atsio
      • Oct 2013
      • 819
      • Greece
      Originally posted by megaraider
      While you wait for the programmer try reseting all BIOS settings to default.
      Incorrect values (assigned or recorded, e.g. temperature, ...) might have been stored.
      To archive this you have to look for a 4 points jumper located very close to the RAM door / socket, labeled "RTCRST" & "SRTCRST".
      Short them all together.
      These are not jumpers but empty pads of resistors to ground.
      " For ICH9/ICH10/Intel
      5 Series Chipset and Intel
      3400 Series Chipset, SRTCRST# is
      used to reset portions of the Intel
      Management Engine (Intel
      ME) and should not be
      connected to a jumper or button on the platform. The only time this signal gets
      asserted (driven low in combination with
      RTCRST#) should be when the coin cell
      battery is removed or not installed and the pl
      atform is in the G3 state. Pulling this
      signal low independently (without RTCRST
      # also being driven low) may cause the
      platform to enter an indeterminate state. Si
      milar to RTCRST#, it is imperative that
      SRTCRST# not be pulled low in the S0 to S5 states
      https://cdn.badcaps-static.com/pdfs/...f19d3672cc.pdf
      • megaraider
        • Jul 2015
        • 307
        • Portugal
        Performing this will clear all BIOS settings stored in CMOS RAM,
        and revert BIOS settings to default safe state.
        Thus any 'incorrect' temperature, voltage, (...) values will be erased.
        Flashing the BIOS (with default switches active) will produce not only the same result,
        i.e., clear all BIOS settings stored in CMOS RAM and revert BIOS settings to default safe state,
        but overwriting the firmware (BIOS) as well .
        • megaraider
          • Jul 2015
          • 307
          • Portugal
          If that doesn't help, neither flashing the BIOS,
          you should begin a more selective approach following the trouble shooting flow chart.
          My advise, having some experience, including with 'compal' motherboards, is to start checking voltages on the LM393 (PU18, mainly responsible for acknowledge voltages presence)
          followed by checking RT8206 (PU16, SMPS).
          These IC's are responsible for many faults on 'compal' motherboards,
          resulting in 'dead' motherboards...!
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            P.S.: about atsio post/opinion
            Aside any controversial I must point out the following:
            The above statement only enumerates the conditions when not to manipulate those signals states,
            not when they could be manually manipulated neither what they are meant to.
            Furthermore, the motherboard schematics even include a very clear not 'close to RAM door'
            - clearly an indication to the PCB design person where those should be located (easy access location point).
            Although not being a much known method, even less described by manufacturers, if you search the web for references you will find step by step instructions on how to perform manual CMOS reset, clear NVRAM and restore default BIOS settings
            – all of which involve the RTCRST and SRTCRST jumpers or pins on desktop and laptop models, respectively.
            Why don't manufacturers refer this information you might ask?
            Perhaps they are more concerned on making money swapping non-defective system boards… imo!
            As a final note I shell say that I commonly use the procedure described with success on fixing related faulty systems.
            Systems with mod BIOS (allowing advance/hidden bios settings), misbehave erratic behaviors (random system reset/reboot) and faults caused by abrupt/forced powered down
            are some common examples.
            • JohnSwe
              • Jul 2015
              • 10
              • Sweden
              #26
              Worth a try!
              I found this:
              If users set a BIOS Password (Supervisor Password and/or User Password) for security reasons, the BIOS will
              prompt for a password during system POST or when the system enters the BIOS Setup menu. If it becomes
              necessary to bypass the password check, users need to short the HW Gap to reset the password by
              performing the following procedure:
              1. Power off the system and unplug the AC and Battery from the machine.
              2. Open the Hard Drive and RAM doors.
              3. Remove the Hard drive.
              4. Remove the mylar as shown in the above figure.
              5. Find the appropriate HW Gap on M/B as shown in the picture.
              • G1 is the RTC Reset. When asserted, this signal resets register bits in the RTC well. Unless
              the CMOS is being cleared (only to be done in the G1 power state), the RTCRST# input must
              always be high when all other RTC power planes are on. In the case where the RTC Battery is
              dead or missing on the platform, the RTCRST# pin must rise before the RSMRST# pin.
              • G2 is the Secondary RTC Reset. This signal resets the manageability register bits in the RTC
              well when the TRTC battery is removed. The SRTCRST# input must always be high when all
              other RTC power planes are on. In the case where the RTC Battery is dead or missing on the
              platform, the SRTCRST# pin must rise before the RSMRST# pin.
              6. Use an electric conductivity tool to short the two points of the HW Gap (G1).
              G2
              G1
              210 Chapter 5
              7. Plug in AC, keeping the HW Gap shorted, and press Power Button to power on the system till BIOS POST
              is finished. Once BIOS POST has run, remove the tool from the HW Gap.
              8. Restart the system. Press the F2 key to enter BIOS Setup menu.
              • JohnSwe
                • Jul 2015
                • 10
                • Sweden
                #27
                That above didnt help.
                I havent yet reflashed the bios... Is it even worth a try?
                • sopik78
                  • Nov 2013
                  • 519
                  • Czech Republic
                  #28
                  Yes, do it. It takes just a few minutes and could help. If not, suspect for other problem.
                  • Inforgalaxie
                    Overheating in Stress Test
                    by Inforgalaxie
                    Hello i have a problem, i have a laptopt Dell E5570 that in stress test without the battery it works good and not turn off.
                    But when i conect the battery and made a stress test the cpu temperature go to 95º and turn off. I also was testing with a new battery and the problem is the same in stress test turn off with big cpu temperature (95-100º). What can be this?
                    12-13-2023, 03:24 AM
                  • bripoll
                    Acer Veriton N4670GT Dead
                    by bripoll
                    Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                    The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                    It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                    I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                    I have programmed it, but it still won't start, it is dead
                    Before programming...
                    11-23-2023, 02:56 PM
                    09-06-2024, 05:27 AM
                    Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                    This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-07-2024, 05:00 AM
                    Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                    This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
