Asus A2L laptop replacement charger
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    As per title, and like everyone else I'm looking to not spend too much
    This one looks good - likely to be Delta, or just counterfeit ?
    http://www.ebay.com.au/itm/New-65W-A...3D161234402311
    Or would this be a better choice, plainly generic ?
    http://www.ebay.com.au/itm/AC-Adapte...3D271311554319
    FWIW, I do have an Australian power cord
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Asus A2L laptop replacement charger
    Always difficult to say. From what I have seen, the counterfeit adapters are getting better.
    But can never be certain what you are getting because they are not easy to open.
    A while back I bought 2 counterfeit Toshiba adapters from the same seller. When I opened them up, they were different designs. They both work well but had no common mode choke on the mains input. This usually causes interference that makes the touch pad operation to be jumpy.
    • rievax_60
      • May 2012
      • 897
      • australia
      It is safer to get a used original although I had to replace the DC plug on the last one I bought. I have also bought ac adapters that had the wrong plug size then changed to one of the correct size.
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Yes, I was wondering if that would be a better option
        • rievax_60
          • May 2012
          • 897
          • australia
          I bought 2 from eBay last week expecting them to not fit my Satellite A200 laptops.
          When they arrived, I found that the plug did fit. As far as I know, Acbel is a good brand.
          http://www.ebay.com.au/itm/Acbel-API...-/171838867069
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Yes I seem to recall that they make decent power supplies.
            By the way, the pictures for the listings might not represent what you get :/
            So it might show a genuine Delta made adapter, but the one you get is some knockoff...
            -Ben
            Muh-soggy-knee
