Hello to everyone! I am not a pro at electronics but i have fixed many motherboards except this one that i am fighting to find out whats going one for one week now! My problem is that tps 51427 is overheating and measuring i find out that 6237ldo5 output is 3.23v and not 5v so following this i discover that pu15 G923-330 when i desolder it the 6237ldo5 is 5.2v! So checked datasheet of tps51427 and i notice that ldo is 100mA out and after pu15 it drains 200mA and i think that this is what is causing tps51427 to overheat!Now i try to put 5 volt manually there and wallah motherboard is working booting normally and tps stop overheating! Now i remove the external voltage and Vin of pu15 is 5.23V and out 3.3V and laptop continue to working for 5 min then dies again with same syptoms! What can this be?
Sony svf15 tps51427 overheating!
Sony Vaio SVF15 Laptop Schematic
DA0HK9MB6D0...-
Channel: Schematics and Boardviews
10-11-2024, 07:43 AM -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:27 AM
by foxerWeird stuff.
I press power on this receiver, I hear the relay click, I can play music and get radio, everything apparently works but not really. The big heatsink stays cold to the touch, the small heatsinks to the two voltage regulators on the mainboard get super hot, and there are two overheated brown areas on the mainboard with an identical pattern (circled in red), centered on the components on each side of the big capacitors (removed in these pictures). Those last components, of course, also get burning hot.
So...I spent the week with my novice skill trying to locate...-
- Loading...
