ASUS K53SV on off itsel
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    I have 3 motherboard with same problem, I got this repair after a year because they handed me a card with the same problems
    1 - if I plug in the ac the fan goes on and off, leds remain on, after a few time the leds goes off and the cycle is repeated. If I try a pwr on/off with button the system goes off and goes on
    2 - only with battery , fan goes on off , leds remain on , but the system does not turn off
    - when the temperature rises, the fan increases but runs unevenly.
    - when system start by itself the cpu, gpu and hm65 are hot
    -all three motherboards had a problem with the ac jack
    I have tried on one motherboard:
    change hm65
    change ite ec
    desolder gpu
    reprogram bios
    someone have fix this issue ?
    thanks
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: ASUS K53SV on off itsel
    maybe you must check tantalum caps for cpu core
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      It's possible to verify the tantalium caps without remove them ?
      or it's possible to verify only if there is a short
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        well , for short onboard will beimpossible , since CPU will make them (like if there were a short) bether to test outside , but this on off thing its like if there was no CPU. could be a bad vcore
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          unfortunately, the vcore voltage is stable.
          I check all Voltage & Signal Measure Point TOP and BOTTOM indicated in a boardview. I noticed, however, when working with the battery does not restart.
          I think the fault is derived from a short on the power pin, because all three board had a problem of this type.
          it's really hard to find this fault.
          • degutji
            • Dec 2012
            • 173
            • Indonesia
            Replace a new GPU ( in my opinion )
            Working on Asus K42JA till today from last week, symptom is when plug in adapter, all indicator on for a few 2nd and off but the fan still on with high RPM ( without pressing any button). Try every possible with no luck, after replaced a GPU chip it working like a normal but with black screen / no display ( replace with GPU from scrap MB ). Conclusion for a while it's GPU defect, in my case still black screen even put known good GPU ( still confuse till I send this post ), stuck on this case, i'm out of idea . But in your case just replace a GPU chip for sure
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              In another board I remove the gpu but nothingh change.
              When I insert the power adaptor, all led are on, gpu, cpu and hm65 are hot , after a few seconds the board goes off and the cycle restart.
              Power button don't work
              With battery , all led are on, gpu, cpu and hm65 are hot and the board remain on and the power button work but the fan runs in spurts
              • senso
                • Nov 2012
                • 21
                • Portugal
                Try this factory Asus Bios, be warned that your Windows 8 key will be erased, so take a note of it before flashing or you will need to call Microsoft to activate your Windows 8.
                • robrock1
                  • Jul 2013
                  • 129
                  • Ghana
                  I have the same problem, i resoldered EC, i suspect broken trace or components. Pwgood suspend all signals ok. Any ideas?
