Blown capacitor? on acer 7739
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Re: Blown capacitor? on acer 7739
    for some strange reason the short to ground problem returned so I can't measure any voltage because when I connect the power it shorts.
    How can I measure what could short to ground (except check one by one)
    • rippergr
      • May 2014
      • 345
      • Ελλάδα
      Can someone give me an idea how to solve this problem?
      • BCConnectionLLC
        • May 2015
        • 47
        Sounds like to me and the looks of the Cap/Resistor you showed earlier, you may have an internal trace short. The layers look lifted around the burnt out piece you showed.
        You can solder a wire on the board for GND and 12V and just push a good amount of amps (the max the computer might pull no need to just fry it) to it and see what happens.
        I had a Samsung Series 7 that had an internal trace short around the Power plug. When I injected 12v from my power supply it smoked right away.
        In those cases its becomes a parts board.
        • BCConnectionLLC
          • May 2015
          • 47
          If nothing smokes or blows up start feeling around for things getting hot. Careful because shorted parts that can handle full load without blowing will get hot enough to blister you in some cases.
          • rippergr
            • May 2014
            • 345
            • Ελλάδα
            Can you tell me where should I inject the 12V?
            • BCConnectionLLC
              • May 2015
              • 47
              At the main power port on the board. There should be fairly large pads to solder to. Just make sure you solder the GND to GND and 12v to 12v pins. Wiring backwards will destroy the board.
              • rippergr
                • May 2014
                • 345
                • Ελλάδα
                #27
                My problem is that when I give power to power jack it short the dc power.
                I must inject voltage after the short circuit component which I don't know how to find it. I already put 19V from a dc power adaptor but nothing get hot or blown it just shorts the power.
                • BCConnectionLLC
                  • May 2015
                  • 47
                  You have to hook up something that will push power without kicking off. I use a Desktop power supply 12V rail and pulse the enable pins on it to keep it from tripping the short safety.
                  Jolted with 12V at a good amp will usually blow things or make them hot that are shorted.
                  • rippergr
                    • May 2014
                    • 345
                    • Ελλάδα
                    #29
                    I don't have desktop power supply yet. I am still looking for something that is good and cheap . I will buy one I hope next week .
                    Is there another way to put voltage to blow or make the component that has problem get hot?
                    • BCConnectionLLC
                      • May 2015
                      • 47
                      Any tower power supply from a computer. Doesnt matter the age. They should all have 12v.
                      • MORETTIGIAN
                        Capacitor detached from PCB – RTX 2070 Super Founders Edition
                        by MORETTIGIAN
                        Title:
                        Description:
                        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                        I did not notice it detaching, so I am unsure of its original location on the PCB.
                        Procedure performed:
                        - Removed backplate
                        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                        - Reapplied thermal compound
                        - Reassembled card
                        Observed behavior after reassembly:
                        - GPU powers on and operates normally under...
                        09-18-2025, 12:14 PM
                      • MeetingIncapable
                        Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                        by MeetingIncapable
                        I am new to repairing computer electronics, so excuse any mistakes I make.
                        A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                        I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                        I wanted to replace the capacitor, but I have two questions:
                        • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                        • How do I determine the rating/value of this capacitor? or something
                        05-04-2024, 09:56 AM
                      • NuclearSpartan
                        Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                        by NuclearSpartan
                        I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                        The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                        I don't see any other visible damage anywhere else on the board....
                        11-14-2024, 02:32 PM
                        09-06-2024, 05:27 AM
                        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-07-2024, 05:00 AM
