Toshiba C50D CRITICAL_PROCESS_DIED
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Hi got Toshiba C50D with AMD E1200 first start normal then after some time using get BSOD with CRITICAL_PROCESS_DIED and after that laptop cant recognize hard disk or anything connected like usb or dvd drive .And if u start again after some time start again normal but every time get that BSOD ansd same shit happening again ,guessing that some of component died if laptop is on for sometime whats triggering dont know maybe temperature or bad bios
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3578
    • slovakia
    Re: Toshiba C50D CRITICAL_PROCESS_DIED
    stat it using live linux os
    • ciki
      • Aug 2014
      • 132
      • Ireland
      How about to fix this one
      • john9871
        • Mar 2016
        • 5
        • India
        I am having CRITICAL_PROCESS_DIED problem in my PC
        • RJARRRPCGP
          • Jul 2004
          • 6304
          It's possible that your CPU core(s) are unstable. Return the CPU core frequencies to stock temporarily, if OC'ing the CPU!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • john9871
            • Mar 2016
            • 5
            • India
            Here's the mail I got for my problem
            1. Have you installed any Windows updates prior to this issue?
            2. Have you made any changes to the computer prior to this issue?
            3. Do you receive any blue screen error?
            Method 1: Perform SFC (System File Checker) and see if it helps.
            System File Checker Tool will try to help you in fixing all the corrupted files and folders in the computer.
            a. Right Click at the bottom left hand side corner of desktop (on Start screen).
            b. Select Command Prompt (Admininistrator).
            c. Type SFC /scannow and press enter.
            Method 2:
            I would suggest you to restore the computer before the error occured.
            Note: Choose a date before the issue occurred as your restore point while performing a System Restore.
            Disclaimer: Performing a System Restore might change your settings and delete your unsaved data. Perform it at your own discretion.
            Or otherwise try this: How To Fix “CRITICAL PROCESS DIED” BSOD? – by deskdecode
            • RJARRRPCGP
              • Jul 2004
              • 6304
              If it's a laptop, the CPU may be failing...
              If not the CPU, then possibly a board issue...
              Arc A770 16 GB
                09-06-2024, 05:27 AM
              • idukke
                Bios of a toshiba C50D-A-13P laptop
                by idukke
                Hi, I need some help, I have a toshiba C50D-A-13P that start up with blackscreen, I would like to check if the bios is OK. I can't find info about my laptop, toshiba is not recognize my model. The motherboard is a PT10AN DSC MB. Could I use a BIOS with the same motherboard model? Thanks in advance
                MODEL. SATELLITE C50D-A-13P
                PART NO. PSCGWE-02T014CE
                SERIAL NO. XD203569s
                BIOS chip: W25Q32FV [3.3V] 32 Mbits, 4 Mbytes...
                07-02-2024, 02:00 PM
                09-06-2024, 05:59 AM
