ISL 6264 problem. Laptop shutdown 1s less
+ More Options
Posts
  • MDY
    • Jan 2014
    • 75
    • Spain
    Have a laptop with MB: Pomona 06244. It is Acer Aspire 5620. It shutdown at less then 1 seg. If I remove CPU it shutdown after 15 seg and I have time to check voltage and miss vcore. If I put CPU I checked again and I really miss Vcore. I tried another CPU and it is not CPU problem. ISL6264 is the core controller and I do have:
    VIN-19V
    VDD-5V
    PVCC-5V
    VR_ON goes to 3.3V when I press power button but it jump down to 0V immediately. I removed r30 (resistor that separate VR_ON from ISL) VR_ON is maintained in 3.3V. So I discard it is VR_ON problem and should be some problem with controller or mosfets, or some caps, but I allready checked caps and mosfets and they are OK. I dont know what do check and what is next. Any idea please?
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: ISL 6264 problem. Laptop shutdown 1s less
    send schematic here. i only found acer extensa 5620. dunno if they are the same.
    • MDY
      • Jan 2014
      • 75
      • Spain
      Sorry, it is travelmate 5520. I attached schematic.
      I have checked for short on caps and near to the ISL and no shorts.
      Also I see there are shorts on U5 and U6 Gate-Source. But this is not really a shorts. After 2,3 minutes no short there. I also replaced these 2 mosfets but the same. When I power up the laptop I check shorts there but after 2,3 minutes no short anymore. Mosfets are OK. Any idea?
      • MDY
        • Jan 2014
        • 75
        • Spain
        No idea? Should I replace the ISL? Can I check something more?
        • Francisco.s
          • 686
          • Spain
          I removed r30 (resistor that separate VR_ON from ISL) VR_ON is maintained in 3.3V. So I discard it is VR_ON problem......
          Have you checked current consumption from dc jack?
          • MDY
            • Jan 2014
            • 75
            • Spain
            Yes, power supply: 0A - 0.60A - 0A. It shutdown in less then 1s.
            • dellxps15
              macbook pro 15 late 2013 shutdown problem
              by dellxps15
              hi all, got this macbook that come with a 45 watt charger. i told the owner to replace it with a genuine 85 watt to check if the shutdown were caused by bad psu power, but the owner didnt want to spent the money if macbook had some other problem related to the mainboard. after some try, i see that notebook shut down even with battery. i did so a log aout last shutdown error and he got 2 main error code: -104 and -128 with one is related to bad battery and one to general failure. i googled a bit and discovered that many user with 2013-2014 macbook were getting the same shutdown like this one.....
              02-25-2021, 04:46 AM
            • NoteX-Bilişim
              Acer 5742g bios for shutdown problem after 5 minutes
              by NoteX-Bilişim
              bios for shutdown problem after 5 minutes / 5 dakika sonra kapanma sorunu için bios...
              12-28-2022, 07:29 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • ahmarzo
              Lenovo nm-b321 v1. 0 shutdown problem
              by ahmarzo
              Have lenovo nm-b321 motherboard it shutsdown after 1 min 10 seconds everytime. Have flashed the bios from official site and flashed ec bios also but same problem. Have checked with or without hard disk. What is the problem please help have checked without the keyboard also.
              10-27-2022, 09:58 AM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
