Re: Acer Aspire One D270 Netbook has no Power or Battery charge Indicator
Well, if PU3 is dead (and it does start to look that way, to me) then there is no way you are getting around it except to replace the chip or the whole board.
SMD work is actually not as hard as it looks, with the right tools and some practice.
If you are willing to make an investment, get a cheap hot air tool on eBay, some liquid flux, solder wick; and practice removing and reinstalling QFN chips on some old\dead boards. There are quite a few videos on YouTube etc which show the process.
The total cost would probably be less than a new motherboard in any case, and you'd have the tools for the future.
If you don't want to do that for whatever reason, then you could try to find someone with a hot air rework tool, they could replace PU3 for you. Again the cost should be less than a new board anyway.
But ultimately, if this isn't just a one-off thing, you really need the right equipment to work on motheboards anyway since practically everything on them is SMT. Without at least a hot air station there isn't much you can replace on them, beyond resistors and capacitors.
Anyway, I hope someone else can give some other advice on the fault because I'm pretty much out of ideas for troubleshooting the board. At this point I would replace PU3 myself and see what happens.
I can think only to say, upload a bunch of photos showing the whole board, both sides, in case there is anything else you may have missed like the missing capacitors.
