Acer aspire D270 no power
  • sasser
    • Dec 2012
    • 365
    • Malaysia
    hye all i details here my problem
    form schematic diagram please see pages 30 from 42. 3cv and 5V system
    i measure
    PU3 pin 19 3v
    Pin 23 no 3v
    Pin 21 no 5v
    PQ14
    pin 4 no v
    pin 1,2,3 no volt
    pin 5,6,7,8 19v
    PQ21 pin 5 no volt , pin 4 no volt
    PD3 pin 1,2,3 no volt
    PL3 no volt.
    what problem here? im tired to settle this are PQ14 is culprit because no volt on pin 4 where it shouldbe 5v or PU3 itself problem
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Acer aspire D270 no power
    how about connection between pin4 pq 14 and pin 21 pu3, how many ohms when measured resistance
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      Check the voltage of PU3:
      1 -
      3 -
      6 -
      8 -
      13 -
      17 -
      18 -
      • sasser
        • Dec 2012
        • 365
        • Malaysia
        i will post later. before this i hear buzz sound. but i dont know from where. i tough PL3 coil then i replace from another working board still nothing. i also lifted the pu3 and put back. now no sound i hear and reading current from my PSU lab is 0.0030 means still not normal.
        i will post here whaldsz the result and thanks to meritosari
        • sasser
          • Dec 2012
          • 365
          • Malaysia
          1 - 0.96v
          3 - 1.98v
          6 - 0.48v
          8 - 3.3v
          13 - 6.32v
          17 - 4.98v
          18 - 3.3v
          continuity test pin4 pq 14 and pin 21 pu3 is ok 0.0002ohm
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            there is a problem with your +5VPCU.
            1. Check the resistance to ground of PQ35 pin 1. There could be a short.
            2. Remove U25 and U23.
            • sasser
              • Dec 2012
              • 365
              • Malaysia
              hye whaldsz resistance checked on pin1 PQ35 to ground i. igot 1.86ohm without u23 and u25
              shouldbe pin3 got +5VPCU right. but no volt on pin3
              • sasser
                • Dec 2012
                • 365
                • Malaysia
                on PU3 VOUT pin24 should 5v give to PL3 but no 5v here
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  give it 2A 3.3V and see where is burning :-)
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    check voltage pin 21, 19 on PU3
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      boardview:
                      always add dash key (-) and number between 1-2 if looking a part
                      ex: pu3-1
                      • sasser
                        • Dec 2012
                        • 365
                        • Malaysia
                        PU3 pin 19 3v
                        Pin 23 no 3v
                        Pin 21 no 5v
                        now buzz sound i dont know from where
                        • sasser
                          • Dec 2012
                          • 365
                          • Malaysia
                          Thanks meritosari . its help me to find the component. how u get .brd format diagram?
                          PQ21 short on ground. pin 1,2,3 has continuity with pin 4,5,6,7,8. with on component damage? already replace PQ21 seem like short on ground and beep sound here from there
                          • meritosari
                            • Oct 2010
                            • 774
                            • Indonesia
                            from china forum
                            I had thought the pin 19 is a little high, it should be around 1v, I have lost a record for pu3
                            cmiiw
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              good news
                              • sasser
                                • Dec 2012
                                • 365
                                • Malaysia
                                pin 19 of pu3 below 1v is that 0.48
                                check PL3 to ground short both side also PC46also short on ground
                                • whaldsz
                                  • Apr 2013
                                  • 395
                                  • Philippines
                                  Lift one side of PL3, then measure resistance on both sides of PL3 with respect to ground. This will help you identify which side is causing the short - the load side or (PQ21 or PU3).
                                  You better use bench power supply as suggested in post #9.
                                  If you don't have bench PS and you found the problem to be located in the load side, try to remove PQ35, PC46 and PC113 and test again.
                                  • sasser
                                    • Dec 2012
                                    • 365
                                    • Malaysia
                                    im sorry whaldsz i dont know the technic suggested in post #9. i have PSU lab. but dont know to inject power
                                    • sasser
                                      • Dec 2012
                                      • 365
                                      • Malaysia
                                      already check resitance with lift one side PL3. left side beep on ground but one side is not
                                      • whaldsz
                                        • Apr 2013
                                        • 395
                                        • Philippines
                                        which side is it? PC46? Then remove these 3 components - PQ35, PC46 and PC113 and test again for short. It could be one of them.
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
