hp dv2000 (0105pm00-600-g) NO POWER
  • YourLocalGeek
    • Feb 2015
    • 43
    • Philippines
    hi guys
    19v present
    18.56 in vbat
    no 3.3v and 5v on coils of u1001
    pin 22 and pin 9 of u1001 is 4.51v is that normal?
    pin 11 and pin 20 no vs
    vreg3 =3.3v
    vreg5 = 5v
    isnt it supposed to output 3.3 in pin 9 and 5v in pin 11
    and is the 18.56 in vbat good?
    vin of u1001 is 18.7v
    checked all mosfets connected to u1001, all are good
    please help
    dont know where to check next
    attached schematics are almost the same
    because the schem is intel, and mine is amd
    thanks in advance guys
  • YourLocalGeek
    • Feb 2015
    • 43
    • Philippines
    Re: hp dv2000 (0105pm00-600-g) NO POWER
    anyone?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      check 3.3V and 5V right when plug in the charger
      check ffor short on 3.3V and 5V coils
      • YourLocalGeek
        • Feb 2015
        • 43
        • Philippines
        thanks for the reply ktm but no short on 3.3v and 5v coil 0v when charger plugged
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          and voltages right when plug in charger? i mean checking voltages and plug in charger. in some cases, voltage come on but after 1 sec it shut off.
          • YourLocalGeek
            • Feb 2015
            • 43
            • Philippines
            still no voltages the instant i plug in charger
            is the ic bad?
            • HOSCARLY007
              dv2000 Tíbet mb bios plz
              by HOSCARLY007
              Buenas tardes necesito la bios
              HP Dv2000
              Tíbet mb
              06241-1
              48.4S601.011
              05-22-2021, 12:20 PM
            • mkdj
              by mkdj
              Mark and model: ASUS X571
              Tests already made:
              - I have removed...
              07-14-2025, 09:16 AM
            • mahmoodjavan
              dv2000 akite mb bios plz
              by mahmoodjavan
              bios plz...
              05-30-2020, 10:45 PM
            • martin83
              Acer nitro 5 AN55-515 fh51m LAJ871P no picture
              by martin83
              Hello everyone.
              I'm here to ask for help troubleshooting an issue with my Acer Nitro 5 An55-515. Board number fh51m LAJ871P .
              The laptop turns on without any image, and after inspection, I noticed the 1.2V voltage was reading 8V spikes. The PQM1 MOSFET's gate was shorted to the source.
              I replaced PQM1, PQM2, and PUM1. After turning on the machine, the 1.2V voltage appears correctly for about 1 minute, but after that, PQM1 shorted again. The MOSFET and controller assembly has already been replaced twice and continues to blow. I can't understand what's going on. I should also add...
              07-14-2025, 06:31 AM
            • mcplslg123
              HP 2000 Dimm Display
              by mcplslg123
              Model:HP2000 series
              M/B:Newton_CR&HR_HPC MV_MB_V1
              Problem is dimm display. I can see image when mobile flash light is used. Exact schematic is not available for this m/b and i've linked a reference scheme which is almost similar.
              Measurement on lvds connector.
              01. Pin29-30(+VBAT)-19V
              02.Pin27(LVDS_PWM)-3.3V
              03.Pin26(BL_Enable)-3.07V
              04.Pin5(LVDS_DATA)-3.3V
              05.Pin4(LVDS_CLK)-3.3V
              06.Pin3-3.3V
              07.Pin1-2(LCDVCC)-3.3V
              Not sharing other pin measurements as i think they are not relevant as i can see a dimm...
              HP Compaq Notebook 431 Schematic 01015FY00-600-G
              04-03-2025, 11:18 PM
