macbook pro a1286 no image on internal but ok on external
  • jeffescortlx
    • May 2011
    • 40
    Re: macbook pro a1286 no image on internal but ok on external
    I've got the same board A1286 820-2915 with the same problems on the 38,39 & 40 LVDS pins.
    The foil for the pins are blown off the board and require jumpers to diode D9701, problem is, I have the schematic but not the component view file, so I have no idea where diode D9701 is.
    If some one could tell me where to jumper to it would be worth 1000 internet points and make me very happy!
    • diif
      • Feb 2014
      • 6978
      • England
      Boardview available in post #2.
      • jeffescortlx
        • May 2011
        • 40
        The schematic is opening, but I'm not getting the board view to open.
        Is it the BRD file? I'm trying to open it with openboardview but it cant.
        • diif
          • Feb 2014
          • 6978
          • England
          Yes it's the .brd file.
          I've just tested on a clean Windows 7 laptop and it opens and views fine.
          • jeffescortlx
            • May 2011
            • 40
            What program are you using to open the BRD file?
            • jeffescortlx
              • May 2011
              • 40
              #26
              I got it to work. Sorry to be such a pest.
              I was trying to drag and drop the file into openboardview. When I manually select file open then it works.
              • piernov
                • Jan 2016
                • 4435
                • France
                #27
                Drag&Drop should work fine too. Are you using the latest release of OpenBoardView (check below)?
                • Marco_compucell
                  • Feb 2012
                  • 66
                  • South Africa
                  #28
                  thank you
                  • xalapamac
                    • Aug 2017
                    • 36
                    • Mexico
                    #29
                    Mil gracias por el esquematico
                    • Noxitos
                      • Aug 2017
                      • 4
                      • Switzerland
                      #30
                      Hello, I'm loocking for A1286 mid2009 logic board ref: 661-5212...5214 shematic diagram or board view. Thank's for my old Mac
                      • audiomodder
                        • Dec 2017
                        • 54
                        Originally posted by dellxps15
                        here is schematic + board view.
                        edit: post good picture of lvds connector zone.
                        Thank you so much for this!!!
                        • fyaagoub
                          • Dec 2016
                          • 269
                          • maroc
                          #32
                          thank you
                          • top1x_sp
                            • May 2018
                            • indonesia
                            #33
                            • thedoger82
                              • Jul 2017
                              • 24
                              • colombia
                              #34
                              Thanks a lot!!!
                              • Siddig
                                • Jun 2017
                                • 264
                                • Sudan
                                #35
                                need 820-2915b schamtic
                                • catono
                                  • Sep 2016
                                  • spain
                                  #36
                                  thanks for the schematic
                                  • bingoeugene
                                    • Mar 2020
                                    • usa
                                    #37
                                    Trying to open brd file but it returns error saying that is has been copied as ASCII - is it possible to upload it as binary?
                                    Or which board viewer shoudl be used - I've tried with Cadence and it does nto work.
                                    Thank you
                                    • bingoeugene
                                      • Mar 2020
                                      • usa
                                      #38
                                      I am looking for the 820-2915-A, Macbook pro, late 2011, 15"
                                      ANy advise where i can get it to be able find the components on the board, basically trying to find how to bypass the Fuse for the backight
                                      • adnanabay
                                        • Aug 2020
                                        • 30
                                        • Turkey
                                        #39
                                        Thanks for the schematic.
                                        • Cactusenterprize
                                          • Nov 2021
                                          • 3
                                          • United Kingdom
                                          #40
                                          Thank you.
                                          • Madoy104
                                            Macbook Pro A1989 - No image, working fine with external monitor
                                            by Madoy104
                                            I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                                            08-15-2024, 10:01 AM
                                          • fasda1984
                                            GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died
                                            by fasda1984
                                            , Hello have same GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died without crash or something, just started in black screen, checked driver in devices and have only external display, no more internal... Any suggestion? External working fine, no problems no errors
                                            06-22-2024, 01:43 AM
                                          • baglaivlad
                                            MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                                            by baglaivlad
                                            Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                                            Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                                            01-09-2024, 09:55 PM
                                          • sdogs
                                            macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                                            by sdogs
                                            Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                                            First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                                            I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                                            06-27-2025, 01:58 PM
                                          • sdogs
                                            by sdogs
                                            06-27-2025, 11:26 AM
