Samsung ATIV Tablet dead
  • Lolomg07
    • Feb 2015
    • 19
    • Srilanka
    Hi so I have a Samsung ATIV 500T Tablet running Windows 8 and recently the power LED died which I traced back to a bad SMD resistor, unfortunately in the process of replacing this I shorted out a small SMD capacitor that was in parallel to this LED, I saw some smoke and the device shut off. The device would not power on so I removed the battery connector and after an hour the device powered on and was functioning as normal for about two weeks. After this I left the tablet unattended for about a week and I think the battery had completely died so I plugged it in and nothing. It was completely dead. I have attached some pictures of the motherboard. I tested every single SMD resistor on the board with a multimeter and they were all good. I'm thinking it's maybe a bad power IC? It has a WINBOND W25Q16BVSIG Bios chip I don't know if this is faulty or how to test it with a multimeter but I have a hot air rework station and I am capable of getting a preprogramed chip off ebay and soldering it on to the motherboard if necessary.
    Please help. Thank you...
  • Lolomg07
    • Feb 2015
    • 19
    • Srilanka
    Re: Samsung ATIV Tablet dead
    Can someone tell me how I can test the bios IC ?
    • vinceroger69
      • Mar 2012
      • 6714
      So when you said (in the process of replacing this I shorted out a small SMD capacitor that was in parallel to this LED, I saw some smoke) Did you replace this capacitor? it mayhave something to do with the charging etc?
      • Lolomg07
        • Feb 2015
        • 19
        • Srilanka
        No this capacitor is just connected to the power LED.
        • Lolomg07
          • Feb 2015
          • 19
          • Srilanka
          Can somebody please try to help me? I really need to get this working. Perhaps there's a power IC we can identify and try to test or replace.
          • Compute
            Master
            • Oct 2014
            • 97
            • Russia
            I understand very little English, write in plain words , what's the problem that I have translated through Google , I'll try to help as well as knowledge in electronics has
            • Lolomg07
              • Feb 2015
              • 19
              • Srilanka
              OK
              1. I tried to replace the resistor marked (1) in the picture and shorted out capacitor marked (2)
              2. The device would not power on anymore since the battery completely lost charge
              • Compute
                Master
                • Oct 2014
                • 97
                • Russia
                If the battery is completely discharged, it has a minimum acceptable level of charge, if the charge is less, the charge controller will not allow it charged, you need to try to charge the battery from an external power source.
                • Lolomg07
                  • Feb 2015
                  • 19
                  • Srilanka
                  When I shorted the capacitor as mentioned in the previous post I saw some smoke and the tablet died and would not power on. So I removed the battery connection it started working 30 mins later after plugging the battery back in.
                  Shouldn't the tablet power on without the battery connected? Just on AC power? Could it be a bad power IC?
                  • Compute
                    Master
                    • Oct 2014
                    • 97
                    • Russia
                    What voltage of the battery now?
                    And give motherboard model tablet, maybe i have a schema/
                    • Lolomg07
                      • Feb 2015
                      • 19
                      • Srilanka
                      2 Volts and the motherboard model just says William Rev 1.0 It's a Samsung XE500T1C-HA1US
                      • Compute
                        Master
                        • Oct 2014
                        • 97
                        • Russia
                        Originally posted by Lolomg07
                        2 Volts
                        This is not enough , at a given voltage , charging will not turn on , the controller will not give
                        • Lolomg07
                          • Feb 2015
                          • 19
                          • Srilanka
                          So what should I do? can I charge the battery externally through a 5V USB cable?
                          • Compute
                            Master
                            • Oct 2014
                            • 97
                            • Russia
                            Labratorny power supply is needed here
                            "5V USB cable" - kil battery
                            • Lolomg07
                              • Feb 2015
                              • 19
                              • Srilanka
                              I don't have one.. any other option?
                              • Compute
                                Master
                                • Oct 2014
                                • 97
                                • Russia
                                3 volts battery needed
                                • Lolomg07
                                  • Feb 2015
                                  • 19
                                  • Srilanka
                                  This battery is rated at 7.5V though
                                  • Compute
                                    Master
                                    • Oct 2014
                                    • 97
                                    • Russia
                                    It is clear now , but nevertheless I charge using laboratrny power supply, how to charge for another , there are options , but they are harmful to the battery
                                    • Lolomg07
                                      • Feb 2015
                                      • 19
                                      • Srilanka
                                      Ok so 3V is not enough? I can try to slowly charge the battery a little at least via USB whilst monitoring the voltage to get the tablet to recognize it
                                      • Compute
                                        Master
                                        • Oct 2014
                                        • 97
                                        • Russia
                                        In general point is to charge the battery up to the level position , while it recognizes the tablet
                                          Samsung ATIV NP915S3G Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung ATIV NP915S3G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP915S3G boardview and NP915S3G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung...
                                          09-06-2024, 05:27 AM
                                          Samsung ATIV XE303C12 Chromebook Specification for Upgrade or Repair
                                          This specification for the Samsung ATIV XE303C12 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the XE303C12 boardview and XE303C12 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung...
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
