asus g53sw problem . weird problem
    Well received this beast , was with problems on dc jack , we've replaced the dc jack , and we tryed the board outside of the chassi , turn on no problem gave image , passed post , well ok . time to close . we assembled the machine very carefully as always , when we tryed to turn on , machine turn on and then turn off . doing this constatly , then i opened the machine again , thinking something of the chassi could making a contact somewere , but doesnt seem , since all is ok . tryed board outside again , and once i insert dc jack motherboard turn on for some seconds then shut off , and there is no response to on off button .
    altough i got 3,.3 and 5 on the coils , but 0 volts on the on off button . but now , if i remove the powerboard , the laptop start working , since i notice gpu and cpu getting hot . but no image . once i insert the powerboard , i notice the 3 led turning on , then stay only on the right led , then shutoff .. and this is what this machine is doing .. i notice than that the connector were the pwoerboard connect , was with some broken part(the little plastic lid was not making pressure on all pins .. so i replaced with a new socket , but same symptom .
    cheked pin 125 of kbc also its 0 volts when it should be 3.3 - replaced the KB -- but nothing .
    i wanted to try to reflash bios but ASUS site gives me a dump with 2.5 megabytes , and the bios is a 4 megabytes ones , i guess that 1 megabyte of the info on the bios must be for the huge pciexpress video card. and the remaining 2.4 megabytes for the system .
    so if anyone here undrstand well about bios cut /repair (usually techman know how to do the work) i apreciate it someone can help me out with this.
    will add here the bios ,
    my dump and the file frmo the asus site . if someone can help me out or have any clues , it will be welcome.
    the file with "dump" writen is my bios .
    Re: asus g53sw problem . weird problem
    can u try without lvds cable and with an external monitor ?
      im working only with the board and to external
        what is the bios chip code ?
          Here my friend full new dump are you getting RSMRST3.3V & S5 3.3V? also caps working or dcjack lit...if not bios ant working .
          Techman1025
            i dont have the bloody schematic for this , but cheking a dv4 board that have this ITE , will chek does values and let you know mate
              well got rsmrst 3.3 but nothing happen when on off is pressed , since there is no responde frmo on off as also no 3.3 volts on the on off as also no 3.3 on pin 125 of kbc (EC_PWRBTN#) , i replaced kbc ,but same symptom persist . (the strange thing is , if there is no powerboard attached to the main board , theboard automatically turn on , but no image at all , if i insert the powerboard on the main board, it will turn on making the 3 leds to turn on for like 5 sec , then only the right led stay on and after 3 seconds it shuts off and will only do this cycle again if i remove the powerboard or remove and reinsert the dc jack)
                also bios does same thing , so i guess bios was ok
                  check also if you have a tps51427, or rtl8206
                    rt8206 is for main regulation , and its working fine
