Toshiba A300D-18A Potomac 10A+/AG+ no Power
  • loser18
    • Nov 2013
    • 274
    Re: Toshiba A300D-18A Potomac 10A+/AG+ no Power
    Yep...
    The regulator is faulty...
    If don't have the same one, there should be some other replacements...
    BTW that aluminium tape is too paranoid,lol...
    I don't use it even when reballing...it's just a youtube blah...
    • magneh
      • Apr 2014
      • 588
      • Portugal
      Originally posted by loser18
      Yep...
      Ahahahah
      Loved that ! Not that I use it for protecting anything from heat, but I've moved small components arround those I'm working @ , like resistors and C's , and to avoid damaging anything arround, I use it as you saw on photos .
      Call it a newbie protection LoL
      I'm doing a reball on a GTX560 Ti and I didn't use it ... no components arround I could accidentally touch
      Gonna try to find a replacement for that regulator on my scrap boards or I will order a new one from Ebay.
      Gonna check that this WD.
      Thanks again, and of course I will update the thread when that new regulator will be in place.
      A good weekend for all
      • loser18
        • Nov 2013
        • 274
        You won't damage anything...if so, you can still solder it back...this way you'll practice steady hands...you'll find out, when you'll be reworking 10-15 mobos a day... (i'm talking about hot air & twezers)
        • magneh
          • Apr 2014
          • 588
          • Portugal
          Hello guys!
          So, after a while without update waiting for the regulator, here's the result.
          Took some minutes to solder this guy back.
          First attempt didn't work out, but on the second one it went good.
          Time to test, adaptor in, led of power went on!
          Good vibes. Measured, 3.3v and 5V are present. Nice!
          Pressed power button, green led lights up, fan starts spinning and ... no image.
          All voltages present OK on the PADS. Fan starts spinning full after 30 secs powering on.
          If I try to power it OFF pressing power button, there's no response from the machine. I can't power it off, only removing power adapter.
          Mesured bios Chip, 3.3V present on pins 3 and 8, 0.8V on pin1.
          So looked at those nasty ATI BGA chips and I've got two of them, as you can see on photos.
          Measured those small caps on the BGA's on diode mode, and found 2 of them shorted (marked those on red on the right side of the 215-0674034 ati chip).
          Is this a bad BGA chip? or should I troubleshoot other components ?
          can a bad BGA chip prevent a laptop from powering off ?
          Or just reball this little bastard?
          Thanks for any inputs!
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3590
            • slovakia
            u can try but i always find it bad
            • magneh
              • Apr 2014
              • 588
              • Portugal
              #26
              So I should get a new chip first?
              Reballing it is a waste of time?
              Could a bad chip prevent a laptop from powering off?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3590
                • slovakia
                #27
                ofcourse if u have bad NB.
                • magneh
                  • Apr 2014
                  • 588
                  • Portugal
                  #28
                  So buy a new ATI chip and replace it that's the way to go right?
                  Those 2 small caps that present themselves shorted are the confirmation of this ?
                  Thanks!
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    #29
                    Beware, that is the Northbridge you are talking about and because you have the discrete version, some of Nortbridge's lines usually are connected to ground.
                    • magneh
                      • Apr 2014
                      • 588
                      • Portugal
                      #30
                      Thanks Atsio for the reminder.
                      So seeing this , do you recommend reballing the north bridge or getting a new one?
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        #31
                        When you say that they are shorted, what is the reading? What is the current drawn when you press the power button? Have you flashed the bios?
                        • magneh
                          • Apr 2014
                          • 588
                          • Portugal
                          #32
                          Hello Atsio!
                          The reading is 0.00 ohm. diode mode.
                          I haven't read the power drawn neither flashing bios.
                          Would be better starting by that I suppose?
                          • magneh
                            • Apr 2014
                            • 588
                            • Portugal
                            #33
                            Hello again!
                            I think I should start by bios flash.
                            Looked for the dump on the web, no joy.
                            This is the A300D-18A unit, model NÂș PSAHCE-0900TPT
                            Board: PT10AP-6050A2172301-MB-A03
                            Could anyone help me with this?
                            Also I've looked at the bios chip, and I see some green stuff on pin 4 , maybe corrosion ... I took a picture, what do you guys think?
                            Change this chip?
                            Or remove it, clean it and reflash it?
                            • Ramee
                              • Jul 2014
                              • 218
                              • Israel
                              #34
                              Try this
                              • Ghost18_07
                                Zakaria
                                • Mar 2018
                                • 75
                                • Algeria
                                #35
                                Hello everyone !
                                So Mr magneh ,, ,, no more response ? worked of not ? well, i think it's worked and he forget to tell us about the results ...
                                  09-06-2024, 05:27 AM
                                  09-06-2024, 05:59 AM
                                  09-06-2024, 05:33 AM
